Local Time 09:25 08 Aug 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Can you put a MM into sleep mode?
Worm
Posted: 12:14am 25 Aug 2011
Same as above.
There's no such thing as a free lunch.
sparkey
Posted: 01:15am 25 Aug 2011
its on the wish list but not as yet can it be put into sleep mode
there is a whis list poll if you look under the heading maximite wish list """ you will come accross the addy for the wish list poll there you can vot for your wish ::: yes i was once a newbie but please use common sense..regards sparkey
Worm
Posted: 02:02am 25 Aug 2011
Thanks sparkey for pointing me to the MM wish list poll. It took a while to find it but I got there. Did you know that common sense is not very common.
Kevin
Xiongmao
Posted: 07:51am 25 Aug 2011
Depending on how much energy you are trying to save, can you reduce the system clock under software control?
