Local Time 08:28 08 Aug 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : bug in LEFT$, RIGHT$ & MID$
BobDevries
Posted: 01:49am 31 Aug 2011
Hi all,
I just now found a bug in the LEFT$() and RIGHT$() and MID$() functions.
Try this:
PRINT LEFT$("hello",1)
PRINT RIGHT$("hello",1)
PRINT MID$("hello,3,1)
Notice that it prints a white block beside the correct output?
Bob Devries
Dalby, QLD, Australia
BobDevries
Posted: 01:59am 31 Aug 2011
Hi all,
just another observation...
the line:
PRINT MID$("hello",3,2)
works as expected; no white block. So it seems to be only on single-character output?
Bob Devries
BobDevries
Posted: 02:09am 31 Aug 2011
Me again :)
It appears that it's sort-of my mistake... I'll explain....
I often run my analog clock programme, and it has a white border about 2 characters wide. If I ESCAPE out of it, the border is left on the screen. Then when a single character is printed, what's left of the border is immediately behind the character on the screen.
Now, IMHO, the print routine *should* clear to the end of the line *unless* a semi-colon is appended to the command.
so,
PRINT "L"
should clear the screen line to the right, and
PRINT "L";
should not.
comments?
Bob Devries
aargee
Posted: 05:41am 31 Aug 2011
Bob,
I think from memory, that most Basics did not clear to the end of the line. I clearly remember having to do a CLS if I wanted a clean slate to work on, now whether it should be implemented in MM Basic, that maybe one for the wish list.
BobDevries
Posted: 05:58am 31 Aug 2011
Hi aargee,
Well, I was comparing against my Tandy Colour Computer 3, which definitely does clear the rest of the line unless the print is terminated with a semi-colon.
Bob Devries
