Forum Index : Microcontroller and PC projects : for those who could not get 2.5c to run
| sparkey Senior Member Joined: 15/06/2011 Location: AustraliaPosts: 819 |
revert to reprograming to 2.5 b or even plain 2.5 if you go to geoffs web site under..."the maxi-m computer" you will find the 2.5 hex files and reload this will get your maxi running ...dont panic all is not lost...regards sparkey technicians do it with least resistance |
| Gizmo Admin Group Joined: 05/06/2004 Location: AustraliaPosts: 5188 |
Hey Sparky The original post from Geoff covered this, it didn't need a new thread. Its better to add to existing posts if its the same subject, only creatre a new thread if its a new subject. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
