Local Time 08:26 08 Aug 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 2Nd SD-CARD help with pinouts
sparkey
Posted: 11:23pm 31 Aug 2011
this is for adding a second SD-CARD
:: SCK1A pin 49 clock to card
:: SDI1A pin 50 data input
:: SDO1A pin 51 data output
::: RD8 PIN 42 CARD ENABLE
:: RD10 PIN 44 CARD PRESENT
:: RD11 PIN 45 CARD WRITE PROTECT
CAN ANY BODY VERIFY THIS FOR ME PLEASE..... REGARDS SPARKEY
Keith @
Posted: 02:15am 01 Sep 2011
Hey sparkey
why the sudden interest in buying SD cards ..... thought you wanted eeprom?
and now you are looking at 2 SD cards on the 1 MaxiMite ... ????
Keith
The more we know, the more we know we don't know !
sparkey
Posted: 04:14am 01 Sep 2011
that`s fascinating even the "trs-80" had twin floppys if you could afford them
VK6MRG
Posted: 04:46am 01 Sep 2011
I think that the reason early computers had 2 floppy drives was because of the amount of disk space at the time was 360k or less. So a program disk was used and the second disk was used for saving data. But now that we have 32Gig SD cards to use, I personally can't see any need for a dual drive Maximite. I have my autorun.bas pointing to a directory on the SD card, and save any log files to the root directory.
Have you thought of just using two different directories?
sparkey
Posted: 04:54am 01 Sep 2011
there are other peop`s creating all different types of mods for the max-m ..
why shouldent my mods account and for myself and any other peop`s any reason ...other than the fact that it may well be possabile
wizard
Posted: 02:42pm 01 Sep 2011
Hi All,
2nd MMC/SD card is a VERY good idea.
But a MUCH simpler way is to:
Use card present input as a /CS for the 2nd SD card.
Write protect can even be repurposed as /CS for a 3rd SD card!
The driver needs to be taught to talk to one card at a time (not hard). And
the language(s) need to tell the driver which card they want to talk to.
My breadboard has 2 - SD cards for all the reasons already mentioned!
warm regards,
Wiz
