Local Time 04:53 29 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Serial LCD
devigan
Posted: 09:05am 06 Sep 2011
Hi guys, anyone with Serial LCD code. I am trying with 2.5F.
100 OPEN "COM1:9600" AS #5
200 PRINT #5, 0xFE, 0X52 ' backlite On but it write 0xFE, 0X52 on the LCD does not carry out any command Help please Dave
sparkey
Posted: 09:10am 06 Sep 2011
2011-09-06_192118_2011-07-09-James-Deakins-LCD-4x20-V2-0.zip 2011-09-06_192228_2011-08-12-Mick-Gulovsen-Arduino-LCD-V1-0_ ALL_FILES_.zip go to the post by gizzmo "tacho with lcd there will be some code in there this may help ...just an idea ...regards sparkey
::: also go to dontronics web page and get on the downloades there is some code there as well follow your nose um i dont have the url for this but if you look through the post "whish list" there you should find a link to dons web page "maximite downloads "...regards sparkeyEdited by sparkey 2011-09-07
jebz
Posted: 09:35am 06 Sep 2011
  devigan said   Hi guys, anyone with Serial LCD code. I am trying with 2.5F.
0xFE is being interpreted as text. Try substituting 254, 82 for your parameters.
BobDevries
Posted: 09:45am 06 Sep 2011
Hi all,
my suggestion would be to use this:
200 PRINT #5, CHR$(&HFE);CHR$(&H52);
The semicolon is necessary at the end of line 200, else a CR/LF will be appended and sent. Note also that the correct syntax for hexadecimal conversion is "&H"; see manual page 6.
Bob Devries
Dalby, QLD, Australia
BobDevries
Posted: 09:56am 06 Sep 2011
A suggestion....
when you're working with I/O streams other than the screen, it's good to send the output to the screen first to see what results. In the above case, the statement:
200 PRINT 0xFE, 0x52: REM truncated somewhat from above"
would produce:
0 0 0 0
hope that helps.
Bob Devries
devigan
Posted: 10:55am 06 Sep 2011
Bob thanks it works
devigan
Posted: 10:57am 06 Sep 2011
and you right I did get 0000
