Local Time 23:07 06 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : analog negative inputs
devigan
Posted: 11:45pm 08 Sep 2011
Hi, any idea on reading plus minus 5 volt input. just wandering how to read negative voltage. Dave
aargee
Posted: 12:51am 09 Sep 2011
If it's on the same ground reference, the easiest thing would be to use an inverting/differential op-amp circuit. Have a Google of it...
Xiongmao
Posted: 07:23am 09 Sep 2011
And if the grounds are different or you need isolation for other reasons, feed the voltage to a V/F chip and output that through an opto. Count the pulses to determine the voltage.
seco61
Posted: 07:31am 09 Sep 2011
It all depends on your ground reference. If the -5V supply was completely independent of the Maximite, then (with an appropriate voltage divider network) you could connect the negative rail to the Maximite ground and the supply 0V line to the Maximite input. Then just subtract the appropriate amount from the result.
However, if there is any risk of common grounds then using an inverting op-amp as mentioned above is probably the way to go (and you can scale the voltage by using appropriate values in the op-amp circuit).
Gerard (vk3cg/vk3grs)
devigan
Posted: 09:05am 09 Sep 2011
it's independent supply so I need some sort of a voltage divider. Thanks
