Local Time 02:59 29 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : printer buy up
sparkey
Posted: 05:54pm 11 Oct 2011
i would like to know if we have enough interest for a printer buy up i will be possibly be able to buy a lot of ten of the printers for use with the maximite ..the printer in question is prolly going to be the one that recomeneded in the post "will we see a printer port" its at the end of page three ..there will be a freight cost as well but this atm is just to see if we have the numbers to make it viable for me ...regards sparkey.....///...///
elproducts wrote:
I've never tried it myself but Sparkfun has this one which is a simple thermal printer that can be controlled via TTL serial.
Should be easy to hook up to Maximite since it works with Arduino.
It sells for $49.95.
http://www.sparkfun.com/products/10438 bigmik wrote:
sorry its the one that sells for lots of ten any way it will prolly work out around 50 dollars plus freight this is not a set price but just an estimate i will also be looking at getting extra print paper rool`s as well if this is a goer,,..regards sparkey
Edited by sparkey 2011-10-13
