Local Time 05:43 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RetroBSD for Maximite
Serge.V
Posted: 07:59am 06 Nov 2011
An alpha release of RetroBSD for Maximite is available: http://retrobsd.googlecode.com/files/retrobsd-maximite-r345. zip
USB port is used for console. No hardware changes or bootloader replacement is required.
___
Serge
jebz
Posted: 09:02am 06 Nov 2011
___
Serge
The USB port reports RetroBSD Console and won't take the Silicon Chip USB serial driver. Can you amend the Silicon Chip driver or change the RetroBSD response on the USB connection?
vasi
Posted: 10:01am 06 Nov 2011
According to revision 346,
[quote=Serge]Porting to Maximite finished. LEDs inverted separately.[/quote]
Vasi
Elvish name: Mablung Miriel
Beyound Arduino Lang
Sumit
Posted: 04:42pm 06 Nov 2011
Yes the silicon chip driver doesnt work. Any fix for this ?
vasi
Posted: 09:40pm 06 Nov 2011
Check the revision #347 ...
Serge.V
Posted: 10:15pm 06 Nov 2011
  jebz said  The USB port reports RetroBSD Console and won't take the Silicon Chip USB serial driver. Can you amend the Silicon Chip driver or change the RetroBSD response on the USB connection?
Oh, really... Ok, I changed the PID to be compatible with Silicon Chip driver. Here is an updated version: http://retrobsd.googlecode.com/files/retrobsd-maximite-r348. zip.
Serge
Olimex
Posted: 09:01am 04 Apr 2012
RetroBSD have remarkable improvements and I test today the latest build, which now have C compiler and it supports PIC32 GPIOs and ADCs with API.
I did small step-by-step tutorial how to setup RetroBSD on DuinoMite HERE
vasi
Posted: 10:32am 04 Apr 2012
Serge have the C compiler still under development. I guess this is his main task right now...
Olimex
Posted: 02:13pm 05 Apr 2012
the C compiler works fine
"In r425 C compiler had an incorrect pathname inside. It’s reported that the issue is identified and already fixed. http://retrobsd.org/topic/bug-ette-in-cc-c/ Fetch newer filesys.img for your SD."
Sumit
Posted: 12:05pm 09 Apr 2012
I am new to RetroBSD. Can anyone tell me where to fetch the newer/latest filesys.img ?
Posted: 01:31pm 09 Apr 2012
I think there's a forum for it so you could ask there if there isn't one on the obvious place (see link above).
vasi
Posted: 02:40pm 09 Apr 2012
  Sumit said   Hi,
It helps a lot if you have a linux machine... (preferably Ubuntu). Then you can get the last svn sources (you have to always do that) and compile them (you also need to get the Microchip pic32 compiler, a package made by Kajita.). See http://retrobsd.org.
It helps also if you have a news feeder, to know when a modification is made to the sources, and the reason developer did it. Then you can decide for yourself if you need to upgrade or not.
VasiEdited by vasi 2012-04-11
phiber
Posted: 02:56pm 20 Sep 2013
Is this topic still active? I have a Colour Maximite. I've tried flashing rev r348's unix.hex, no problem there. I power cycle, and absolutely nothing happens. No lights, no USB/serial device detected, absolutely nothing. I can flash back to MMBASIC and everything is fine again. So it would seem no one has tested this lately on a Colour Maximite...
Mark
Posted: 07:58pm 20 Sep 2013
Haven't seen anything on here for ages but see the obvious place(s) :)
Posted: 09:35pm 20 Sep 2013
RetroBSD was ported to the monochrome Maximite. The Colour Maximite is different in many ways so it is not surprising that it will not work.
Serge.V
Posted: 09:10pm 21 Sep 2013
Colour Maximite in several essential respects, which make it impossible to run the kernel from the monochrome Maximite.
  • Memory map had changed. Now the user area of flash memory starts at 0x9d005000 (was 0x9d003000).
  • For SD card chip enable, signal A1 is used (was E0).
  • For power LED control, signal E0 is used (was F0).
I prepared a RetroBSD binary package for the Colour Maximite: https://retrobsd.googlecode.com/files/retrobsd-maxcolor-r891 .zip
It was tested using CircuitGizmos CGCOLORMAX2 board.
--Serge
Posted: 02:02am 22 Sep 2013
UNIX on a Colour Maximite. Just amazing.
Thanks Serge.
phiber
Posted: 11:41am 22 Sep 2013
Awesome! I'll try it out later today. Has it been officially added to the source tree in r891?
-Mark
  Serge.V said   Colour Maximite in several essential respects, which make it impossible to run the kernel from the monochrome Maximite.
--Serge
Serge.V
Posted: 06:23pm 22 Sep 2013
Yes, of cause: all the changes have been checked in as r891. You can see the kernel configuration file here: https://code.google.com/p/retrobsd/source/browse/current/sys /pic32/maximite-color/MAXCOLOR
--SergeEdited by Serge.V 2013-09-24
paceman
Posted: 07:12pm 22 Sep 2013
Serge,
This is a great piece of work for Maximite family users. Have you considered adding it to the MMBasic library. I don't think the library is just for programs written in MMBasic but for the advancement generally of the Maximite community.
Greg
