Local Time 23:34 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Configure Putty
elchucko
Posted: 03:26pm 17 Nov 2011
I'm using Windows 7 and would like to configure Putty. When attempting to run Putty I get an "unable to open connection COM1, unable to open serial port". I left all setting but "serial" to default. Is there a sample configuration setup for using Putty to communicate with the Maximite SM1? Thank you
donmck
Posted: 03:42pm 17 Nov 2011
  elchucko said   I'm using Windows 7 and would like to configure Putty. When attempting to run Putty I get an "unable to open connection COM1, unable to open serial port". I left all setting but "serial" to default. Is there a sample configuration setup for using Putty to communicate with the Maximite SM1? Thank you
Is COM1: correct in device manager?
You have the serial driver installed?
PuTTY is good, but try MMIDE by CircuitGizmo. it may make things easier, as you don't have to figure out your comms port for one thing.
http://www.themaximitecomputer.com/max/Programs/index.php?di r=Software%2FMMIDE+Terminal+Program+by+Rob+Severson%2F
Cheers Don...
https://www.dontronics.com
CircuitGizmos
Posted: 05:08pm 17 Nov 2011
Thanks for the 'plug', Don. I've already fixed the blank line problem for saved files and added two additional features. I will be adding enough VT100 support to fix backspace and CLS.
Then XMODEM support.
elchucko
Posted: 05:20pm 17 Nov 2011
MMIDE (is hiding somewhere on their we site). ;)
CircuitGizmos
Posted: 06:00pm 17 Nov 2011
  elchucko said   MMIDE (is hiding somewhere on their we site). ;)
I'll post an update in a day or so.
Meanwhile: http://www.circuitgizmos.com/files/MMIDE.zip
donmck
Posted: 08:16pm 17 Nov 2011
I have placed CG's latest MMIDE Terminal driver at the URL above, however it is a work in progress and doesn't have the full features yet.
Cheers Don...
donmck
Posted: 09:16pm 17 Nov 2011
Sorry CG, getting this error on both MM and DM when I click on the set date:
> date$ = "Nov18-11" : time$ = "8:14:30"
Error: Invalid syntax
I know it is a work in progress, but thought I would let you know before others do.
Cheers Don...
CircuitGizmos
Posted: 09:37pm 17 Nov 2011
Ah crumb.
I thought it would be a fast/quick feature. Apparently my code is being thwarted by the country "locale" setting.
I think I know a work-around. Besides "move to the U.S." :-D
donmck
Posted: 09:43pm 17 Nov 2011
  CircuitGizmos said   Ah crumb.
I felt it would be a local OZ setting.
Can you get me a green card at my age?
Cheers Don...
CircuitGizmos
Posted: 09:47pm 17 Nov 2011
I can get you a green circuit card.
elchucko
Posted: 12:24am 18 Nov 2011
OK, it looks like I should not have asked the question. No green card needed!
CircuitGizmos
Posted: 12:54am 18 Nov 2011
Heh!
Already fixed Don's problem (on my copy). Will roll that fix into the next public MMIDE update.Edited by CircuitGizmos 2011-11-19
