Local Time 00:19 29 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Basic Program
elchucko
Posted: 04:13pm 19 Nov 2011
How do I attach a .bas program to a post? Thank you
sparkey
Posted: 04:24pm 19 Nov 2011
first you have ti zip it then attach it to the post using the little icon that is showing that zip picture its the last one on the right ....actully i think if you just click on the picture next to the zip icon it will ask you to browse and then from that select the file that u want to attatch ...i think that the zip icn button may zip the file for you and then it will prolly attatch it .....Edited by sparkey 2011-11-21
elchucko
Posted: 06:49pm 19 Nov 2011
2011-11-20_044538_aceyducey.zip
I'm new at this. I found the attached Basic program that is not compatible with M. I believe it's a Tiny Basic program. Any programmers out there that can have a look at it? I'll learn some Basic here! Thank you
brucepython
Posted: 07:52pm 19 Nov 2011
After a minute or two trying it out ACEYDEUCY2.BAS seems to work fine Chucky. I'm trying to determine how to get my winnings of $320 printed, but I can't find a printer driver to hook up the Maximite to my fancy hires printer. Darn!
The only changes I suggest are disposing of all those capital letters in the text and, because I'm painfully picky, changing line 1030 to
1030 IF LEFT$(A$,1)="Y" OR LEFT$(A$,1)="y" THEN 110
in case anyone else is also too lazy to type "YES".
You'll also need to shorten the filename to eight characters or less.
Bruce
elchucko
Posted: 08:08pm 19 Nov 2011
2011-11-20_060727_blackjack.zip
Oops, I sent the wrong file. It's this one.
Gadget
Posted: 12:26am 20 Nov 2011
to get it to work i just had to alter line 30 from
30 DIM R(15)
to
30 DIM R(15),Z(5)
This then allows for 5 players if you want more change the 5 to the number of players
apart from this it seems to work, might want to do a bit of work cleaning up the output
cheers
Terry
elchucko
Posted: 02:42am 20 Nov 2011
Thanks Terry. I'm using HyperTerminal. I have a program listing within the HT screen. How I delete the data? I can't seem to clear the HT window of the program listing. Thank you
