Local Time 19:16 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMIDE Questions v 1.0
DuinoMiteMegaAn
Posted: 08:32pm 02 Dec 2011
DuinoMite Mega
Firmware: 2.7 (Factory)
Patform: PC Win XP/SP3
Questions:
#1. On a DuinoMite Mega manual pushbutton reset or power on reset, the serial link, if connected hangs and locks up. Is this normal?
Shouldn't there be an auto serial disconnect?
#2. On Load to MM using the backspace to correct typos will flash the whole screen erractically on each backspace key entry. Is this normal?
Note: On small basic programs it doesn't flash but on larger programs it does?
Otherwise its a great program!
Edited by DuinoMiteMegaAn 2011-12-04
CircuitGizmos
Posted: 08:48pm 02 Dec 2011
1) I would like to be able to detect loss of the serial port and do something about it. Unfortunately the driver just goes away and there is no signal to my program that it has happened.
2) There is a trade off, there. I allow the screen to roll back, which is the cause of the flashing. Perhaps I should just have a fixed and non-scrolling screen?
Thanks! Working on an update.
DuinoMiteMegaAn
Posted: 02:43am 05 Dec 2011
On MMIDE 1.0 "Save from MM" includes the "command prompt".
Only code with "line numbers" should be transferred from MM to the PC.
CircuitGizmos
Posted: 12:22pm 05 Dec 2011
  DuinoMiteMegaAn said   On MMIDE 1.0 "Save from MM" includes the "command prompt".
That was something I fixed and then broke. I'm still sitting on the newest version that SHOULD have it fixed again. I'll announce it here when I release it.
DuinoMiteMegaAn
Posted: 08:02pm 10 Dec 2011
Not to nickpick ... since banging away at the keyboard for my application code, I came across some very annoying MMIDE problems. (Version 1.0)
#1. It seems that using the command CLS to clear the MMIDE window does not clear everything. It sometimes leaves text debris and/or garbage on the screen. (after a clear screen command) I have to do several CLS to clear it.
#2. There are sometimes a large abnormal delay going from one text menu to another. I figure at 30,000 - 40,000 lines per second execution for MMBasic there is something else going on? (Something is hanging the code execution in MMIDE)
Note: None of these problems shows up on the video console.
Otherwise, MMIDE is a great program! Edited by DuinoMiteMegaAn 2011-12-12
CircuitGizmos
Posted: 12:39am 11 Dec 2011
Work is still continuing on MMIDE.
I will look into #1.
For #2, are you doing a CLS between your menus?
(Perhaps this all relates to a CLS issue...)
CircuitGizmos
Posted: 04:00pm 11 Dec 2011
Andy: Check your Personal Messenger.
