Local Time 19:16 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : (MM) Here’s an Easy One
elchucko
Posted: 09:48pm 07 Dec 2011
When using Tera Term, I try sending the clock program listed on Geoff's web site and various programs errors show up in the program listing. I assume it's a .bas Tiny Basic program? Where am I going wrong here? Thank you
BobDevries
Posted: 10:14pm 07 Dec 2011
If you're referring to the CLOCK.BAS programme inside the ZIP file Analog_Clock.ZIP, I'm the culprit who cobbled that together.
All .BAS files related to the Maximite, refer to MMBASIC files.
You didn't tell us what the errors were, nor when they were appearing.
One gotcha when sending files to the Maximite via TeraTerm, is that you need to set up TeraTerm with a line delay, so that the MMBASIC interpreter has time to process each line as it receives it.
To set up the delay, there's a pull-down Setup->Serial Port. Change the Transmit Delay->msec/line to some value other than 0 (try 10).
Hope that helps.
Bob Devries
Dalby, QLD, Australia
elchucko
Posted: 10:43pm 07 Dec 2011
Thanks Bob. I set the delays to 10ms. Works! Line errors 2,8,216 unknown commands
