Forum Index : Microcontroller and PC projects : Oustanding Maximite Box
elproducts![]() Senior Member Joined: 19/06/2011 Location: United StatesPosts: 282 |
Check out this box designed for the original Maximite board developed by member Rawmicro. I think this is an absolutely awesome design and just had to share it.
(The board inside is just a scrap test board) www.elproducts.com |
| Gizmo Admin Group Joined: 05/06/2004 Location: AustraliaPosts: 5198 |
Someone's got access to a laser cutter
Nice looking box, and see its even got a slot for the SD card at the front. Good work. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
| JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 4385 |
Nicest box I recall ever seeing. |
