Local Time 14:36 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : (DM) How many GPIOs you can use on DM?
Olimex
Posted: 07:29am 17 Jan 2012
The correct answer is 22! I hope this simple demonstration will finally stop the discussions about the number of the DuinoMite GPIOs which can be used.
How many GPIOs...
The above setup is with DISABLED SD-CARD and only internal DRIVE A:
Also in this demo the VGA video is disabled to may use PIN(20) and in this case you can use only the composite video output or the color Gameduino shield for Video output.
The Latest DM firmware have BASIC command: SDDISABLE and SDENABLE so you do not have to run SETUP command and reset the board to disable the external SD-CARD.
The next firmware of DuinoMite will have also BASIC command for VGA enable/disable which will have as side effect increasing the program code execution speed by removing the video generation.
Posted: 09:10am 17 Jan 2012
Cool!
I hope the wrong web page(s) will now be edited/removed by those who created/host them.
centrex
Posted: 09:20am 17 Jan 2012
Glen
Looks like you will be zapping another item from the forum.
Cant you blokes give it a rest, the DM and the MM are both great devices.
Give credit where credit is due.
I dont see anyone rubbishing the CGMMSTICK just because it looks a little different to the above
Cliff
Cliff
Posted: 09:23am 17 Jan 2012
Stop it, now! Back on topic please.
djuqa
Posted: 09:28am 17 Jan 2012
Funny how the DESIGHER of the Duinomite didn't even know how many GPIO's could be controlled.
VK4MU MicroController Units
Olimex
Posted: 09:33am 17 Jan 2012
sure this was side effect of our ignorance ;)
the UEXT signals were not intended to be used as GPIO, the two extra signals are the real COM3 UART Rx, Rx which is available on UEXT connector (you can see the wires from UEXT)
Ken just noticed that if you do not use this UART you can drive them as GPIO and add this to the firmware
Posted: 09:56am 17 Jan 2012
  centrex said
Glen
Cliff
Hi Cliff,
I wrote some code (not the code quoted by Tsvetan) and did the design for the led/switch tester and I did this for TWO purposes,
Firstly to show that the DM can control all 20 IO lines and is not crippled as has been reported. But secondly and most importantly, it was to test all MM and DM boards to ensure that the basic functions were working.
My wish is to show that the MM and DM are more closely related than is generally thought.
I dont want this constant tongue poking as it is not constructive... The DM and MM are similar but NOT the same.
I am not happy that this has been broached openly in the vein it has been.
I believe that Tsvetan has been under so much flack about this that when I shared this with him he grabbed it and galloped forward faster than I could blink...
Whilst I am happy, ecstatic actually, that someone appreciates my work ... My wish is to unite the DM and MM community and not divide it...
I think the fact that Tsvetans native tongue is not English he has inadvertently worded it like a tongue poke rather than an announcement of news.
Please dont turn this into something it wasn't intended to be...
I love both the DM and MM and they belong together and not at opposite ends of the court.
Posted: 11:09am 17 Jan 2012
Well said Mick. We just dont need the unhelpfull comments, all they do is tarnish an informative post. The fact that the Duinomite can access so many pins is a good news.
If your a Duinomite user, and the post is about a Maximite, or visa versa, then let it be.
Back to the topic.
Olimex
Posted: 05:27pm 29 Jan 2012
  djuqa said   Funny how the DESIGHER of the Duinomite didn't even know how many GPIO's could be controlled.
oh dear, shame on me again, I'm looking at DuinoMite schematic again and found two more GPIOs PGC and PGD on ICSP connector!
I'll ask Ken to add these in the definitions as PIN(24) and PIN(25) so total 24 GPIOs are available for use and drive independantly.
I'm afraid to look again as I could find some more
djuqa
Posted: 05:19am 30 Jan 2012
Go for it mate.
ALL the more the merrier.
Edited by djuqa 2012-01-31
Olimex
Posted: 05:43am 30 Jan 2012
BTW Don just had an briliant idea to use the ICSP connector as new UEXT like connector as you have there power supply and 2 GPIOs it could become nice Wii Joystick port!
ICSP is used just once at the time of bootloader programming then unused
we will make small wii joystick adapter board which connects to ICSP
djuqa
Posted: 05:59am 30 Jan 2012
Now you talking! A great Idea
VK6MRG
Posted: 02:19am 03 Feb 2012
Just think how many I/O's we would have if someone had the guts to design a MM or DM with the 100 pin PIC32!! Then we could still have 20 dedicated I/Os and EVERTHING else as well!!! And not have to sacrifice functions like the SPI bus or SD card etc for extra I/O's!
I've been asking the question for over 6 months and I've only been told it's too hard or use the UBW32 (which I have but only as a development/prototype tool.
Let’s see the DM use a 100 pin chip and have EVERYTHING with no compromised MM I/O's!
Posted: 02:42am 03 Feb 2012
  VK6MRG said   Just think how many I/O's we would have if someone had the guts to design a MM or DM with the 100 pin PIC32!!
Hi VK,
Olimex is bringing out the eMega soon that may suit your purpose...I havent yet checked out the schematic to see about shared pins but it does use the 100 pin jobbie..
eMega ..
djuqa
Posted: 02:56am 03 Feb 2012
Hi VK,
eMega ..
Yes especially on something like the DM e-mega
Lots I/O, connectors and support bits for Gadget freaks.
VK6MRG
Posted: 03:29am 03 Feb 2012
Looks promising! Well done to Olimex and everyone else working on the e-mega!
aargee
Posted: 07:53am 03 Feb 2012
  VK6MRG said   Just think how many I/O's we would have if someone had the guts to design a MM or DM with the 100 pin PIC32!! Then we could still have 20 dedicated I/Os and EVERTHING else as well!!! And not have to sacrifice functions like the SPI bus or SD card etc for extra I/O's!
So, why can't you use the UBW32? I have it running on a piece of vero board with video, keyboard and SD Card connected.
Or are you after a complete built PCB with all the peripherals already there?
It really shouldn't be too hard to drum up a board design for a "Super-Maximite" (you heard it here first, folks!) using the 100pin PIC, with all the peripheral support circuitry on board and then use the UBW32 version of the firmware.
Though, I'm quite happy with the UBW board format for my tinkering.
- Rob.
VK6MRG
Posted: 08:10am 03 Feb 2012
- Rob.
Actually I first talked about a super maximite last year, but nobody wanted it!
I did try and design my own PCB using the 100 pin PIC32 But soon gave up as I would have been the only user.
Now I have the UBW32 I'll play with it.
Matthew
