Local Time 15:19 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PAL NTSC
teun
Posted: 01:31pm 20 Jan 2012
Hi maybe a stupid question but is it possible to change the video output between pal and ntsc?
CircuitGizmos
Posted: 01:49pm 20 Jan 2012
CONFIG COMPOSITE NTSC | PAL
The COMPOSITE setting will change the timing for the composite video output. Default is PAL.
The CONFIG command differs from other options. It permanently reconfigures MMBasic and it only needs to be run once (ie, the setting will be remembered even with the power turned off). The power must be cycled after changing a setting for it to take effect.
teun
Posted: 04:10pm 20 Jan 2012
Thanks!
