Local Time 15:19 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Help - Number to Character String Convert
Ray B
Posted: 02:35am 02 Feb 2012
Got a mind block converting a number to a string as follows for displaying a temperature value from a DS18B20 to an LCD display using recently published subroutines, as follows:
timestring$ = "Time is: " + Time$
PrintLCD 1, timestring$
Pause 1000
above works fine but when I try adding a Temperature value it comes to grief. i.e.
GetTemp 4, Temp
Temp$ = Chr$(Temp)
temperature$ = "Temp = " + Temp$ + "degrees at: " + Time$ ' ignore character exceeds 20 characters for the LCD this is just an example
PrintLCD 2, temperature$
Pause 2000
OK Chr$ will returns a one-character string consisting of the character corresponding to the ASCII code indicated by argument 'number'.
BUT the temperature reading will be more than one character e.g. 25.0625 degrees
so how do we convert this to a simple character string suitable for display ?
Help welcome....Cheers
RayB from Perth WA
CircuitGizmos
Posted: 02:49am 02 Feb 2012
How about converting the number to several single digit variables?
temphi = int(temp/10)
templo = temp - (temphi * 10)
then chr$ the temphi and templo values.
djuqa
Posted: 02:50am 02 Feb 2012
Temperature$=STR$(temp)
[Quote=maximite manual]Str$(number) function returns a String in the (Base 10) Representation of 'number' [/quote]Edited by djuqa 2012-02-03
VK4MU MicroController Units
CircuitGizmos
Posted: 03:29am 02 Feb 2012
  djuqa said   Temperature$=STR$(temp)
That's it. I shouldn't watch TV and try to think at the same time...
Ray B
Posted: 03:38am 02 Feb 2012
djuga not up with my basic programming - overlooked Str$ - this solution only works with integers (i.e. ignores fractions of degrees) but thanks for the quick response.
Gizmos gets the prize for looking at Hi & Lo parts .
Following code works great - I've left a few delays and print statements in for dignostic purposes.
GetTemp 4, Temp
temphi = Int(Temp)
templo = temp - (temphi)
temphi$ = Str$(temphi)
Print "temphi$ = " + temphi$ : Pause 1000
templo$ = Str$(templo)
templo$ = Mid$(templo$,3) ' this is to ignore leading 0.
Print "templo$ = " + templo$ : Pause 1000
'Temp$ = Str$(Temp)
temperature$ = "Temp = " + temphi$ + "." + templo$ + "C"
Pause 2000
James is about to release some 4 x 20 LCD code using subroutines that I've been testing with him & I'm using this to obviously obtain temperature from DS18B20 & displaying on LCD. After James releases his code (maybe later today) I'll tidy this application up for others.
Next stage will be to incorporate it into some if the previously posted Data Logger code.
Cheers all
RayB from Perth WA
Posted: 05:47am 02 Feb 2012
Str$() should print fractions. If does not it is a severe bug. (EDIT: or have I misunderstood?)
You can use the Format$() function which has greater control of the formatting. But (on the downside) it does take some time to understand its syntax.
GeoffEdited by Geoffg 2012-02-03
BobDevries
Posted: 07:00am 02 Feb 2012
Hi all,
Indeed STR$ *does* convert floating point numbers. Example:
a=1.25:PRINT STR$(a)
1.25
Works fine.
Bob Devries
Dalby, QLD, Australia
Ray B
Posted: 07:22am 02 Feb 2012
Interestingly I've looked at the code, made a few changes and STR$ does show fractions.
Anyway I learn a lot from Gizmos' code offering.
For those interested my final code extract is as follows:
for loop = 1 to 10
GetTemp 4, Temp
Print "original num = " + Str$(Temp) ' prints on PC for diagnostic purposes
temperature$ = "Temp = " + Str$(Temp) + " C"
PrintLCD 3, "Loop Count = :" + Str$(loop)
Pause 1000
Next loop
All demonstrates how great it is today to have subroutines. Thanks guys
RayB from Perth WA
djuqa
Posted: 07:27am 02 Feb 2012
Code looks good
Subroutines RULE!
