Local Time 14:37 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : a "BASIC" scope :)
YT2095
Posted: 02:09pm 08 Feb 2012
This is just for a bit of fun,
here is a Very simple program that will turn your MM/DM into a very crude low frequency Oscilloscope, although for BASIC, it`s not too bad!
10 setpin 1,1
20 cls
30 for x=0 to 479
40 pixel(x,(pin(1)*128))=1
50 next
60 goto 20
this make analog pin 0 into the input, and it`s wise to put a 10Mohm (or more, I use 100Mohm) resistor between A0 and +5v to pull the X axis down towards the middle of the screen, if you have only a 10M resistor then use the +3.3v rail, but this isn`t writen in stone, so play about until you`re happy the Y axis is roughly center screen with no signal.
in line 40, the "128" value is the Gain for the Amplitude, experiment with that also, 128 works nicely here, and I can pick up a good sine wave with a 6 inch bit of wire on A0, that will increase as I bring my hand near to it.
I can`r really think of any real-World application for this beyond demonstrating the principal behind a scope trace as Input over Time, but my kids love it!
and if you find any way to make this Faster (less waves per screen) and in realtime, please post your work-around/solution, I`d love to see and try it.
have fun! :)
Raros
Posted: 06:50pm 09 Feb 2012
Great YT2095.
Very interesting.
Raros
ksdesigns
Posted: 07:08pm 09 Feb 2012
this is my version ..
http://www.kenseglerdesigns.com/cms/forums/viewtopic.php?f=4 &t=170
10 CLS
20 DIM ynew(480):DIM yold(480)
30 SETPIN 1,1
40 x=0
50 PIXEL(x,140-yold(x))=0
60 ynew(x)=PIN(1)*50
70 PIXEL(x,140-ynew(x))=1
75 yold(x)=ynew(x)
80 x=x+1
90 IF x > 480 THEN x=0 ELSE GOTO 50
100 END
ken
YT2095
Posted: 12:48pm 10 Feb 2012
I just tried your program, and after only a few minor adjustments, I must say it`s a Lot neater than mine on screen.
seeing the Dimension array you used, also made me wonder how fast the board would be capable of writing the A0 pin data to the SD card, to make a sort of Storage Scope?
again, it would probably be of no practicable purpose, but would certainly serve to demonstrate the principal behind it.
being quite New to this dev system, but no stranger to BASIC, I wonder if ASM can be used in the code like on the BBC Micro for instance? hitting the metal directly would certainly speed things up a little were it possible.
Thanks for your input each! :)
