Local Time 13:51 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM-teraterm
palcal
Posted: 07:59am 13 Feb 2012
Trying to load a program into the Mini-Maximite using Tera Term. Have set the delay to 50 ms per line but when I paste it is if the program runs as it is pasted and I get error messages all through the pasted program. Eg. 'No more data to read' and a lot of 'cannot find the label'.
Can someone run me through how to do this.
Thanks, Paul.
Posted: 08:38am 13 Feb 2012
  palcal said   Trying to load a program into the Mini-Maximite using Tera Term. Have set the delay to 50 ms per line but when I paste it is if the program runs as it is pasted and I get error messages all through the pasted program. Eg. 'No more data to read' and a lot of 'cannot find the label'.
Thanks, Paul.
Hi Paul,
l I am not sure this is related but I found that when I wrote long lines in notepad and copied them in with TT that I had to make sure that the notepad didn't do a line feed in the middle of a long line, I had to set the font to 8 pt or it pasted like a split line into TT..
Posted: 09:48am 13 Feb 2012
Are you pasting lines without line numbers? In that case MMBasic will think that you are typing in a lot of commands to be executed immediately. You have to use the AUTO command without any parameters.
palcal
Posted: 09:13pm 13 Feb 2012
OK I used the Auto command and the program pastes but I cannot save it. I tried pasting in Edit mode but the program pastes all over the place. I must be doing something wrong.
Paul.
Posted: 09:29pm 13 Feb 2012
You must terminate the AUTO command with CTRL-C. Then, you can save, edit, etc.
You cannot paste in the edit mode because the editor has to do a lot of work (scrolling, etc) and it cannot keep up with the data rate.
AUTO works. It is in the manual.
palcal
Posted: 09:51pm 13 Feb 2012
Yes, sorry about that I found out if all else fails read the manual.
Sorry for the trouble.
Paul.
