Local Time 21:25 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Oscilloscope - Data Logger
Bill.b
Posted: 05:22am 15 Feb 2012
Hi all
This may be of interest to any one requireing a cheep oscilloscope/datalogger/Logic analyzer suitable for fault finding logic circuits.
It was developed by Wolfgane Maichen, the Kit costs approx AU$73.00 including
postage.
The unit is powered from then USB port and solftware is free.
more information ca be found at http://www.dpscope.com
Olimex
Posted: 06:58am 15 Feb 2012
PIC32 ADC sampling is 1Msps i.e. you can implement something better than this one with just Maximite/DuinoMite!
djuqa
Posted: 07:06am 15 Feb 2012
  Olimex said   PIC32 ADC sampling is 1Msps i.e. you can implement something better than this one with just Maximite/DuinoMite!
Sounds like a good idea for a Project
VK4MU MicroController Units
Ray B
Posted: 08:35am 15 Feb 2012
The full history of this project is on the PicAxe Forum
http://www.picaxeforum.co.uk/showthread.php?20378-Simple-osc illoscope-for-Picaxe-work-finally-finished!-%28DPScope-SE%29
RayB from Perth WA
Posted: 08:55am 15 Feb 2012
True, it would make a good project for a 'mite. Plus it would eliminate the need for a PC, we could use the 'mites own VGA and keyboard interface.
But I think it would need a bit of fast C to do the sampling, MMBasic would only be quick enough for a few hundred Hz bandwidth.
Or is there a fast sampling chip we could use to sample, store and send via serial?
pickle9000
Posted: 03:01am 30 Mar 2012
Being able to grab a sample would be great.
Playing it back would also be a great way to make waveforms. Play a single word or some cool sound effects. The pic32's are made for it. I guess the real issue would be that the sample would eat up memory fast. Even so it would be worth it.
As for a chip to do the work, there is always a better chip but the cost of making it work is always a hard barrier to beat. A 1meg sample rate (if that is what it can do) will be more than enough for decent audio range sampling. I expect that Microchip even has a sample capture routine to get a person started. I wish I had the time to play more.
Man I really like this idea I hope it does not die.
...mike
plover
Posted: 09:58pm 10 Jan 2016
Well it looks like the project died or has another attempt been posted?
I am currently looking/searching forum for anything "datalogger" Edited by plover 2016-01-12
Ray B
Posted: 10:40pm 10 Jan 2016
Welcome to 2016.... Data Loggers have advanced & only cost a couple of $$$ using Arduino. Follow this YouTube link
https://www.youtube.com/watch?v=XAxv0fr26_8
RayB from Perth WA
Posted: 11:01pm 10 Jan 2016
A 'mite (with CFunction as needed) can surely do better, if anyone wants/needs to.
(If you need faster/better still, there's a Raspberry Pi one.)
As the CPU used in the Arduino one has so little RAM, as well as being rather slow, I wonder how limited it is? ("Very" is my feeling.)
JohnEdited by JohnS 2016-01-12
Posted: 11:09pm 10 Jan 2016
  Quote  A 'mite (with CFunction as needed) can surely do better, if anyone wants/needs to.
I've already written the cfunctions for both an Oscilloscope and logic analyser but they need someone to write a user interface to make them properly usableEdited by matherp 2016-01-12
Chris Roper
Posted: 12:01am 11 Jan 2016
  matherp said  ... but they need someone to write a user interface to make them properly usable
Have you seen the SUMP Logic Analyzer Client it is a java app so should run on any PC, and the protocol is well documented and it can display the Logic Analyzer output as well as do protocol analysis and Scope Display.
There is a third party one too, that uses the same protocol, I will try and find it.
Chris
EDIT:
Here it is http://ols.lxtreme.nl/
With sump as the display and Micromite as the active component all we need is a decent front end.
Edited by Chris Roper 2016-01-12
http://caroper.blogspot.com/
Ray B
Posted: 12:07am 11 Jan 2016
  JohnS said   A 'mite (with CFunction as needed) can surely do better, if anyone wants/needs to.
The original request by plover was for "anything datalogger" so it's to that I'm responding although some people may think this forum is just for Mites.
Following is some data I've just saved every second to SD card suitable for importing into Excel, being 3 Analog inputs & 3 Dallas Temp Sensors. This is all running on a $4 NANO with a SC Card & RTC modules. All up less than $10.
For those interested the Arduino IDE now has a charting capability built-in.
1,2016/01/11,17:55:09,A0:=,807,A1:=,600,A2:=,560, T1:= 28.19,T2:= 28.06,T3:= 28.19,
2,2016/01/11,17:55:11,A0:=,807,A1:=,665,A2:=,613, T1:= 28.19,T2:= 28.06,T3:= 28.19,
3,2016/01/11,17:55:12,A0:=,807,A1:=,679,A2:=,627, T1:= 28.19,T2:= 28.06,T3:= 28.19,
4,2016/01/11,17:55:13,A0:=,807,A1:=,688,A2:=,641, T1:= 28.19,T2:= 28.06,T3:= 28.19,
5,2016/01/11,17:55:15,A0:=,807,A1:=,703,A2:=,655, T1:= 28.19,T2:= 28.06,T3:= 28.19,
6,2016/01/11,17:55:16,A0:=,808,A1:=,705,A2:=,663, T1:= 28.19,T2:= 28.06,T3:= 28.19,
7,2016/01/11,17:55:17,A0:=,807,A1:=,700,A2:=,659, T1:= 28.19,T2:= 28.06,T3:= 28.19,
8,2016/01/11,17:55:19,A0:=,807,A1:=,697,A2:=,656, T1:= 28.19,T2:= 28.06,T3:= 28.19,
9,2016/01/11,17:55:20,A0:=,808,A1:=,709,A2:=,668, T1:= 28.19,T2:= 28.06,T3:=
Cheers all
RayB from Perth WA
geraldfryjr
Posted: 01:21am 11 Jan 2016
I am always looking for projects like this.
I have a nice little scope program that I found a while back that runs on my STM32F429i-Disco board.
It works very well and is open source and I think can be found on git hub.
I was able to compile it using CooCox and cerate the Hex file and I think that it is also already provided in the download files.
First Oscope
Here is a Gogole search where you can find it and probably a few more examples.
Oscope
Cheers!!
jer Edited by geraldfryjr 2016-01-12
Keep on DIYin' !!!
Ray B
Posted: 01:38am 11 Jan 2016
And for an introduction to using Logic Analyser you can't go past attached.
http://www.ebay.com/itm/USBEE-AX-PRO-Logic-Analyzer-Learning-board-programmer-w-DuPont-Lines-for-SCM-/261732056134?hash= item3cf0723c46:g:97QAAOSwzrxUs5iK
Or for a basic CRO
http://www.banggood.com/DIY-Digital-Oscilloscope-Kit-DSO062-DIY-Kit-p-981554.html
RayB from Perth WA
Posted: 02:16am 11 Jan 2016
SUMP's the one I posted about previously.
A $5 RPi is an idea for it once the zero is available easily :)
Wish there was a $5 (or $4) 'mite. Nearest rough equivalent I have was about $10 (ready-built board with PIC32 MX170).
kiiid
Posted: 02:40am 11 Jan 2016
  JohnS said  Wish there was a $5 (or $4) 'mite. Nearest rough equivalent I have was about $10 (ready-built board with PIC32 MX170).
Well, now there is a $0 one
I am willing to give away a certain number of pre-allocated Microkite modules until the quantity is exhausted. You pay for the postage only, that's about a pound.
Edited by kiiid 2016-01-12
http://rittle.org
Posted: 03:12am 11 Jan 2016
That's a good price! Any better ones anyone? (*)
umm, the module concerned doesn't look like something that obvious or easy to use. At a quick look I couldn't tell what CPU is fitted, how I connect to it (or even read the full info at first as the web page doesn't fold the text to the browser window size).
I gather it needs a carrier board with a socket, or some such?
(*) not expecting any!
kiiid
Posted: 04:18am 11 Jan 2016
(*) Don't count on it
Someone might come with a negative number offer...
Yes, the module will need a holder because in essence it imitates an IC, just integrated with some extra stuff on it. The MCU is MX170.
http://rittle.org
Posted: 05:02am 11 Jan 2016
Yes, you never know!
How much is the carrier? (To compare prices, the board I mentioned is a fully-populated one, with chip, etc.)
kiiid
Posted: 05:09am 11 Jan 2016
Well, the problem is that I am running out of carriers right now.
Generally it is £1.35; DEB2-1001W68 is the board.
http://rittle.org
