Local Time 11:14 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GSM MOD Duinomite Mini
Hneo2au
Posted: 03:57am 03 Mar 2012
Has anyone had success With wth GSM-Mod board as I am having trouble getting any data output. I have used the sample code http://olimex.wordpress.com/tag/gsm/ and corrected an error on line 100 but I cannot get the module to respond. I have checked with the scope that the Dunomite is sending data but as yet I have had no response from the module at all. The status led say that the module in connected to the Network.
Lindsay
Olimex
Posted: 06:29am 03 Mar 2012
Lindsay please use support@olimex.com to report your problem
please write what power supply etc you are using, if the sim card you out in the module is pin free etc as much as possible info so our tech support people can track what you do wrong
Hneo2au
Posted: 08:16am 03 Mar 2012
Thanks, I have reported the problem as you suggested.
timor
Posted: 01:26pm 11 Mar 2012
Hi, did you manage to solve this? I have exactly the same problem and had success in sending SMS with one of the examples. So sending seems to be working but receiving does not.
Timo
Olimex
Posted: 02:26pm 11 Mar 2012
please send e-mail to Lubo support@olimex.com and he will respond
when SMS is received the GSM module send string which is several lines
I think I posted code somewhere about how to handle the incoming strings and get the useful info inside
Tsvetan
Hneo2au
Posted: 10:33pm 11 Mar 2012
I had a response from Olimex regarding the connecting cable, connect only Pins 2,3,4 in the uext cable. ( Lubo suggests cutting the cable but I just jumpered the three wires and it works).There appears to be a conflict with the other connections. Also you have to send the command "ATV1" to the modem to set the response is messages rather than numbers.Bit of a steep learning curve, but satisfying when you work it out. I thank Olimex for it response.
regards
LindsayEdited by Hneo2au 2012-03-13
Hneo2au
Posted: 09:34am 14 Mar 2012
Just had an update from olimex support "A little update on MOD-GSM + DuinoMite.
Now I did manage to do find that the problem is that DuinoMite is keeping the CTS line high (1), which stops the send messages by the GSM chip. If you set the DuinoMite PIN6 low (0) it should work without cutting the cables:
5 SETPIN 6,8
9 PIN(6)=0
timor
Posted: 04:59pm 26 Mar 2012
Lindsay (and Tsvetan), thanks!
Finally I got it to work also. I should say that I did write to Olimex support too and got exactly the same instructions, but I had a newer version of the firmware (DMBasic) which has some issues on the COM3/4 -ports and requires a pullup resistor to work. I just burned an older version (MMBasic) and now I get response from the module.
Timo
vk4tec
Posted: 02:06pm 06 Apr 2012
Have you guys had any success with GPRS ?
Or is SMS the furtherest you have gone ?
Andrew
Andrew Rich VK4TEC
www.tech-software.net
Olimex
Posted: 08:42am 07 Apr 2012
Did you read the AT commands PDF? on the last pages there are examples how to establish TCP-IP and GPRS link. I didn't try these as I had no need to use TCP-IP or GPRS through GSM as it's expensive way to send data.
vk4tec
Posted: 10:14am 07 Apr 2012
Not really expensive
GPRS is through to UDP on my LINUX box
SMS is old and bulky
Andrew Rich VK4TEC
