Local Time 12:01 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Serial input problem (MM)
brucepython
Posted: 12:41am 10 Mar 2012
I'm trying to read a serial stream from a GPS "mouse" with the following code:
Open "COM1:4800" As #1
Print Input$(1,#1);
Loop Until 0
It's reading data, but the data makes no sense. The GPS unit is working perfectly with a PICaxe-based display.
The NMEA stream looks fine on the oscilloscope.
If anyone has a suggestion of where I've gone off the rails then I'd appreciate it.
Bruce
Sample hex data:
6D 76 36 2D 96 AD 16 DA 76 56 2D 96 59 BD AE 15 65 4D 3B D6 6D 36 6D AC D9 B2 B3 6D B6 76 6D D9 D9 5A 96 B3 DA DA DA B5 59 57 BD AE B5 2B B6 F6 76 76 AD F6 96 D9 AC 2D AD 76 76 D6 B6 AD D9 F6 DA F6 F6 ED AD 16 D6 5A F6 F6 96 D6 B6 5A BB 95 EB D7 15 C5 F5 B6 F6 76 56 2D 16 F6 96 D9 AC 2D AD 76 76 D6 B6 AD D9 F6 5A ED 36 ED D6 2D ED F6 96 56 D6 AD 5A D6 5A DA D6 56 AD 5AD6 DA 65 79 BD AE 15 65 F5 EB 3B D6 ED ED 6D3 6 6D 16 6D DA DA DA DA DA DAB 6D AD 62 DE DB 62 DE D3 69 5E BB 77 15 F7 15 95 3A 79 9A7 9 DA 79 D9 DA 79 F9 DA 79 D8 FA 79 D9 B9 FA 79 99 3A 79 F9 7A 79 F8 FA 79 F9 D9 9A 79 B9 3A 79 F9 1A 79 F9 3A7 9F 959 9A 79 B9 1A 79 F8 FA 79 98 FA 79 F9 39 9A 79 79 DA B9 17 5E 5E BB 77 15 F7 15 95 3A 79 9A 79 BA 79 D9 DA 79 F8 DA 79 D9 7A79 B9 B9 1A 79 98 DA 79 D9 DA 79 D9F A7 9D
boss
Posted: 04:58pm 10 Mar 2012
do you use signals on TTL or RS232 level? Remember that TTL defines start bit as logic "0" but on RS232 it is +12V. Simply - RS232 is negated and level shiftet TTL. Another problem could be wrong speed, number of data bits or parity settting. Hope this helps.
brucepython
Posted: 01:41am 11 Mar 2012
Thanks boss for those suggestions. The data is definitely at TTL levels so I'll try stripping the start and parity bits (though I'd have thought the the serial input code would do this) and see how that goes. The data shouldn't have any high bits set (which many seem to be in that dump) as it's straight ASCII text with no characters over 126. The speed is definitely 4800 Bd, but I'm unsure about the GPS device's bits and parity settings because its documentation, if it ever existed, is now long gone. Even the code I wrote for the PICaxe seems to have gone into hiding. Unfortunately I have to drive a few hundred km this afternoon to collect various family members so shall have to postpone further twiddling until tomorrow.
I really appreciate your reply - many thanks.
Bruce
vk4tec
Posted: 09:07am 25 Mar 2012
Bruce,
Some thoughts
+ Voltages - TTL ? RS232 ?
+ Inverted / non inverted
+ Protocol - Plain text NMEA / Binary ?
+ Speed
+ Parity
+ Stop bits
+ ASYNCH RS232 or USB serial data ?
Are you seeing 8 bits of ASYNCH on your scope ?
I was going to invert some of your data in software but the synch could be anywhere.
Brand of GPS ?
Andrew Edited by vk4tec 2012-03-26
Andrew Rich VK4TEC
www.tech-software.net
boss
Posted: 03:15pm 25 Mar 2012
Hi Bruce,
If remember well, the "main" RS232 channel on PICAXE has no RS232 receiver/transmiter chip but just few resistors and diode which means it is definetely working with reverse signal polarity. To be 100% sure you have check Tx on GPS when module is not sending data (idle). The Tx pin in idle state must be on log 1. Serial channel seems to be very simple but some time (wrong setting, inacurate Tx speed)it can be real pain. I'm using Maximite COM2 port for communication with serial LCD/VFD display (send data)and unfortunatelly have no experience with data receiving.
boss
brucepython
Posted: 07:56pm 25 Mar 2012
Thanks, gentlemen. I've been diverted by another project and less-than-perfect health, but shall follow up your suggestions ASAP. I followed up on some of Andrew's suggestions and have established that the data is definitely ASCII, definitely at 4800 and definitely at TTL level.
From what boss has deduced from the PICaxe having no problems, I'll now try tackling the signal polarity. The GPS unit is a Techway TP-051 "mouse". Not the latest and greatest, but very reliable and rugged.
Again, many thanks for your ideas and support.
Bruce
