Local Time 12:02 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Is my board broken? DM 2.7a
robarino
Posted: 03:36pm 18 Mar 2012
HELLO!
I have the duinomite mega and I have been trying my best to conduct a frequency count. I have tried everything and I am ready to give up on this board :(
I have plugged in both a wave generator at 3 to 5 volts as well as a fez panda and arduino into pin 11. Nothing else plugged in.
I have then typed
[code}
10 setpin 11,5
20 for i=1 to 100000000
30 print pin(11)
40 next i
[/code]
It just runs and runs as 1111111111
The funny thing is that when I setpin 11,2 I can see the wave as 111000111000111000
I need to count increments less than 1 millsecond and I was going to do this with the sound out. This board is plenty fast enough to need a counter less than 1 millisecond.
Posted: 08:21pm 18 Mar 2012
I have then typed
[code}
10 setpin 11,5
[/code]
Hi Rob,
Which version Firmware are you running? If you have Geoffs port of MMBasic installed I dont know which pins are compatible for frequency Input.
If you are using the OLIMEX version the correct pins to use are Pins 5,6 or 7
I am making the assumption you are running the OLIMEX version here, (as I dont know off hand which pins are to be used in Geoffs 12 pin IO port to DM.)
To read a frequency the pin should be set using SETPIN 5,3
SETPIN 5,4 is for PERIOD
SETPIN 5,5 is for count
If these dont work flash a later firmware, see list HERE
