Local Time 12:02 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PULSE problems on UBW32
Dave Everett
Posted: 04:47am 21 Mar 2012
I have MM3.1 loaded onto a UBW32 and have been testing the PULSE command and found it varies greatly.
I am using pin 20 for all my tests and a Saleae
logic analyser to measure the pulses.
Pulse 20,2 gives varying pulse widths anywhere from 1ms to 1.5ms.
If someone else has a UBW32, could they check and see if they are getting similar variability.
Thanks,
Dave
ernie
Posted: 05:34am 21 Mar 2012
From the MMBASIC 3.1 manual:
  Quote  PULSE pin, width
Will generate a pulse on 'pin' with duration of 'width' mS.
'width' can be a fraction. For example, 0.01 is equal to 10 μS This enables the generation of very narrow pulses.
The generated pulse is of the opposite polarity to the state of the I/O pin when the command is executed. For example, if the output is set high the PULSE command will generate a negative going pulse.
Notes: For a pulse of less than 1 mS the accuracy is ± 1 μS. For a pulse of 1 mS or more the accuracy is ± 0.5 mS. A pulse of more than 1 mS will run in the background. 'pin' must be configured as an output.
So if the pulse is 1ms or more, the accuracy drops to ± 0.5 mS as it runs in the background.
That may be your problem.
Try some pulses less than 1mS and see how accurate it is.
Edited by ernie 2012-03-22
Dave Everett
Posted: 05:56am 21 Mar 2012
I totally missed that Ernie. I read it as 0.5us not ms, but you're right, the accuracy drops significantly.
I'll run some tests next week.
Dave
