Local Time 10:26 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GPS Logger SD Card
vk4tec
Posted: 11:35pm 23 Mar 2012
Hello,
New to the forum.
Been programming PIC16 in ASM for a while GPS USART LCD etc.
Recently discovered the MaxiMite and now DuinoMite.
ie ASM --> BASIC implementation.
I have a project.
To log to an SD card that can be read by a PC, from a NMEA GPS.
Input is either RS232 or TTL
Output is SD CARD to store NMEA.
I see some code for GPS parsing and SD card file writting.
Anyone done this ?
I think I might try a MaxiMite first .
I have a bitscope BS10U coming
I used to have a DSO on the bench
Here is my website
www.tech-software.net
- Andrew -Edited by vk4tec 2012-03-25
Andrew Rich VK4TEC
djuqa
Posted: 12:08am 24 Mar 2012
Welcome from another QLD Amateur
VK4MU MicroController Units
vk4tec
Posted: 12:10am 24 Mar 2012
Thanks Matey
What sort of projects are you using the MaxiMite for ?
Is Altronics the best place to get one ?
I am hoping to be able to pop a GPS inside the Maximite case and piggy back a battery .
- Andrew -
Andrew Rich VK4TEC
djuqa
Posted: 12:16am 24 Mar 2012
I have 3 Duinomites (mini,regular,max) and two maximites (1 SM1 clone from Dontronics, no longer available) and 1 custom. Altronics & Jaycars kits are very expensive (Approx 100$ posted, Slighly less for the Mini-Maximite).
Dontronics & Silicon chip sell the bare boards & Silicon chip has the pre-programmed PIC32. The rest of the components are fairly standard and easily obtained.
The Duinomite and CGMMSTICK are a cheaper prebuilt solution with some limitations & advantages.
I am currently testing/developing a MM/DM based Cat controller for Yaesu FT-897 And (Other model) Radios.
Edited by djuqa 2012-03-25
vk4tec
Posted: 12:46am 24 Mar 2012
Hey cool - I did not know JAYCAR sold the mini Maximite
I can grab that and add some connectors and program
I see the firware and chip are already there.
I would need to add
+ VGA connector for screen
+ PS2 connector for keyboard
+ SD CARD holder
+ Power ?
I have GPS
I am a bit confused over how to
+ Make the device pick up a program on start - SD Card ?
+ Make STDOUT equal to the VGA screen or can the USB be used as a dump port ?
mini Maximite looks 3.3 Volts - best way around this ?
- Andrew -
Andrew Rich VK4TEC
djuqa
Posted: 01:37am 24 Mar 2012
maximite basic manual
vk4tec
Posted: 02:00am 24 Mar 2012
Yes I think I will make a hard copy and keep it out
I went to JAYCAR and now have a miniMaxiMite
+ VGA will be via a DB15HD connector
+ Keyboard will be flying leads to an inline PS2 socket
+ SD card - I could only get a MultiCard type reader - may even solder straight to card
+ Power - 3 volts from plugack
+ GPS - TTL maybe - have to work that out
Maybe I can can get away with a "dump" command and just "replay" the SD CARD file back to USB serial hyperterm ?
Andrew Rich VK4TEC
vk4tec
Posted: 02:41am 24 Mar 2012
Looks like the miniMaximite has some room inside the chip and then on the SD card
+ My program will reside on A: ( the internal 256 kb MEM )
+ My GPS NMEA data will reside on SD card "B:"
A: 256 KB
B: 2GB
A: Should contain "AUTORUN.BAS" to start auto magically
or
B: Should contain "AUTORUN.BAS" to start auto magically if not on A:
- Andrew -
Andrew Rich VK4TEC
Posted: 06:04am 24 Mar 2012
  vk4tec said   Thanks
Hi There vk....
I love it when someone maps out what they want to do before they do it...
Great work...
I am curious though. Why did you select a miniMaximite if the next thing you wish to do is add VGA, Add SDcard, Add K/B and then require 5V (TTL) as well?.. A full maximite would have had all that built in or even a Duinomite as well would have all the things you need. DM Mega even has DB9 with RS232 level signals available as well.
If size was an issue the DM mini possibly could have fit the bill there (no RS232 level though)
djuqa
Posted: 06:12am 24 Mar 2012
Exactly my thoughts
like buying a mini and stretching it into a BUS.
vk4tec
Posted: 06:15am 24 Mar 2012
+ Size - I wanted to start smaller and grow the design
+ Availablility - JAYCAR is down the road, I can start learning today
+ I was not sure I needed VGA, or KB figured I would add then remove as necessary
+ I figured I would add outboard VGA and KB until I worked out it I needed it or not.
+ I have x2 spare 5 volts reg ccts I can use.
+ I read obout Altronics not having stock - gamble
+ Did not know about DM Mega
- Andrew -
Andrew Rich VK4TEC
djuqa
Posted: 06:28am 24 Mar 2012
No worries Mate
All good.
Geoffg designed the mini with separate section for VGA/KB for exactly that reason
Use it or leave it out if not needed.
DM mini regular is the same and has a daughter board with the video/audio/KB connectors
So in final application can be removed or remotely fitted.
Once Mini-MM is up and running you may have to update the firmware to latest version 3.1.
The download links you need at Geoffg.net .
P.S. I am available on skype as DJUQA_Support.
vk4tec
Posted: 06:48am 24 Mar 2012
I think my SD CARD slot can go where the space is at the end of the miniMaximite
Will connect VGA and KB as needed.
I have mapped out my LED usage. GPS, SD Card in use light.
I think I might write AUTORUN.BAS onto the SD CARD as well.
I have a mate with interests in UAV and video - hence the VGA interest. (ATV)
These boards are awesome - they get over the hurdle alot of people starting out have - programming the CHIP and the code.
I was taught PIC in Assembly and understand the REGISTERS.
I have another project pending - 7 Segment GPS clock
Will report back with results soon (ish)
- Andrew -
Andrew Rich VK4TEC
vk4tec
Posted: 07:38am 24 Mar 2012
Guys,
What are your thoughts on getting 3.3 volts from a voltage divider from 5 volts ?
I see that the prefered method is a VREG LM317 etc
I need some 5 volts which will be dead on for other parts of a CCT ie Regulated.
I see the MiniMaximite wants 2.3 to 3.6 V ( or says the notes that came with it )
I will check the PIC datasheets. for the PIC32MX795F521H-80I/PT. and PIC32MX695F512H-80I/PT voltage limits.
- Andrew -
Andrew Rich VK4TEC
djuqa
Posted: 07:57am 24 Mar 2012
Really need to use a LM1117 3.3v or similar regulator.
This can use the 5v Rail as the input.
The SD CARD needs at least 2.9v to be reliable.
vk4tec
Posted: 07:59am 24 Mar 2012
Hey it just dawned on me
5 volts through a diode of 1.7 volts drop = 3.3 volts
Andrew Rich VK4TEC
Posted: 10:10am 24 Mar 2012
  vk4tec said   Hey it just dawned on me
Voltage divider is a NO-GO as the voltage will fluctuate depending on the load the MM draws... and current needed to go through the divider means you will be drawing a fair bit of current just due to the divider..
Rectifiers tend to drop .6-.7V so you would need to use 3 in series and get between 2.9V and 3.2V (depending on the specifics of the rectifiers).. better off using a regulator or using the miniMaximite in another application and getting a DM mini or DM Standard (or Mega if you want the RS232). IMHO
vk4tec
Posted: 11:23am 24 Mar 2012
Thanks Mick
Duino seems the go
Andrew Rich VK4TEC
vk4tec
Posted: 10:25pm 24 Mar 2012
Guys I am a bit confused over the SD card size on the duino mini and standard
Micro SD
Is that the one that fits in a transflash carrier board to make it into a standard SD size card ?
I read the duino docs from front to back and am quite excited about what they can do.
I also need to work out 20x4 LCD
I also gave a 8x7 LED with MAX chip I need to work out
I see the duinos can even charge a LIPO
Yeah mick the mega was a bit large for me
My GPS is UART compatible TTL
Today I will code up GPS_SD
In anticipation of arrival on duino mini and standard
Andrew Rich VK4TEC
djuqa
Posted: 10:40pm 24 Mar 2012
Thread Discussing 20x4 LCD usage.
The OLIMEX Duinomite range uses the MicroSD format Card as does the CGMMStick. Yes, this is the card Form-Factor that needs an adaptor to fit in standard SD/TF sockets.
These cards and adaptors are readily available.
