Local Time 12:02 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Synchronous Serial Record Playback
vk4tec
Posted: 09:28pm 26 Mar 2012
Hello
I often need a quick source of SYNCHRONOUS serial data for testing CCTS
That is a clock and data to go with it.
5 volts logic is fine.
I think it is possible to :-
Record ( pin test )
+ Look for a clock rise
+ Wait a bit to land data pulse in a bit
+ Save value of data pin to file.
+ Record all this to a file.
Playback
+ Read in file
+ Grab next data value
+ Set data pin for data high low
+ Set clock pin high for xx us
Should be pretty easy to implement ?
5 volts TTL clock and data recorder
- Andrew - Edited by vk4tec 2012-03-28
Andrew Rich VK4TEC
www.tech-software.net
crackerjack
Posted: 02:38am 28 Mar 2012
I think you are talking about a Logic Analyzer here, perhaps (at least the "record" part)? I just don't think that interpreted basic will cut the mustard in terms of speed...
From memory (there are posts on the forum about MMBasic speed on a Maximite), I recall that purely flipping an output from Low to High (and vice versa) in a loop was running at speeds of about 12 - 14 kHz. Add to that the need to read data from an SD card, twiddle the bits on two output pins, etc. and I think a goal of 64 kb/s is "outside the zone".
Maybe I'm wrong; thoughts anyone?
