Local Time 10:24 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Invert ttl
vk4tec
Posted: 03:08am 15 Apr 2012
Hello
Duinomite mini
Is it possible to use the pic32 to invert TTL serial ?
I think you use a comparator and come back out again ?
Firmware ?
Basic command ?
Pin assignment ?
TTL GPS not uart compatible need to invert
Andrew
Andrew Rich VK4TEC
www.tech-software.net
Posted: 05:33am 15 Apr 2012
  vk4tec said   Hello
Andrew
Hi Andrew,
To Read/Write/Both?
TTL levels required or 3.3v levels.
boss
Posted: 03:35pm 15 Apr 2012
Hi Andrew,
the easiest way to invert signal polarity is using a npn transistor ie 2N3904 with a collector resistor 4k7 to 10k connected to +3.3V and ~ 10k resisor coonted between GPS Tx and trasistor base.
This will work as signal inerter and voltage level converter as well.
Hope this helps
Regads,
boss
