Local Time 10:24 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : [MM-DM] MaxiMite-DuinoMite and SimmStick.
donmck
Posted: 04:52am 17 Apr 2012
I have recently received some private email regarding interfacing the MaxiMite and DuinoMite to the SimmStick bus, and felt some sort of explanation of events is in order to help explain the situation.
There has been some recent chat on TBS forum that reminded me that I should produce some up to date answers: http://www.thebackshed.com/forum/forum_posts.asp?TID=4876&PN =1
And there has been a couple of recent spin-off features from the Test-a-Mite MM-DM-CGMMSTICK1 GPIO tester board.
1) CGMMSTICK1 to Maximite-DuinoMite 26 pin GPIO Adapter.
2) Maximite or DuinoMite board, to SimmStick Adapter.
Full story at:
http://www.themaximitecomputer.com/maximite-duinomite-and-si mmstick/
http://www.duinomite.com/maximite-duinomite-and-simmstick/
Cheers Don...
https://www.dontronics.com
CircuitGizmos
Posted: 03:55pm 17 Apr 2012
There is also the DT208 if you still use SIMM sockets.
donmck
Posted: 05:45pm 17 Apr 2012
  CircuitGizmos said   There is also the DT208 if you still use SIMM sockets.
Thanks Rob, unfortunately, there are very few of these DT208 left in stock:
http://www.dontronics-shop.com/dt208-5-by-5.html
Cheers Don...
CircuitGizmos
Posted: 05:51pm 17 Apr 2012
The board that I really miss is the DT202 2" proto. I should have bought those early.
donmck
Posted: 05:57pm 17 Apr 2012
  CircuitGizmos said   The board that I really miss is the DT202 2" proto. I should have bought those early.
For those wondering:
With your CGMMSTICK1, and standard boards, not using Simm sockets, would basically a 2" by 30 pins board work for you Rob?
Cheers Don...
CircuitGizmos
Posted: 06:03pm 17 Apr 2012
The groovy thing about the DT202 was that the board length, the bottom two mounting holes and the bottom row of 30 holes lined up with the two sticks that I made: the CGMMSTICK1 as well as the CGU401 USB interface .
donmck
Posted: 07:52pm 17 Apr 2012
Understood Rob,
would it be worth making your own DT202 equiv.?
Cheers Don...
