Local Time 10:25 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : command SETUP on Duinomite ?
f1fco
Posted: 12:40pm 05 May 2012
hello from F1FCO,
I own a Duinomite on version 2.7A
the command SETUP (v 1.3) is very useful for RTC card
I use OLIMEX MOD-RTC with PCF8563
my question : does this command SETUP (and use of RTC on boot) exist in version 3.1 or 3.2 of MMBASIC ?
thank you for answer
73s from F1FCO
73s de F1FCO
donmck
Posted: 05:01pm 06 May 2012
  f1fco said   hello from F1FCO,
73s from F1FCO
Hi Pierre,
I also saw that you posted this question on KSD forum, and didn't get an answer.
To my knowledge, there is no "setup" command in standard V3.x MMbasic.
So you would either need to use DMbasic, or write a driver in MMbasic, to support the Olimex RTC.
Cheers Don...
https://www.dontronics.com
