Local Time 10:25 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Found a bug in MMBASIC Editor
cosmic frog
Posted: 02:12pm 13 May 2012
I may have found a bug in the MMBASIC 3.2 editor.
If I go into the editor and try to READ an empty DATA statment it crashes the Maximite (or in my case the UBW32)
READ A
DATA
Will cause it to crash with the message - "An internal error was trapped and your program has been lost (sorry). Were you using the PEEK or POKE commands?".
Posted: 01:13am 14 May 2012
Thanks, yes that is most definitely a bug.
I try very hard to make sure that nothing could crash the interpreter because that results in the user's program being lost - so this will be top of the list to be fixed in the new version.
djuqa
Posted: 04:39am 14 May 2012
Could a "on error goto" statement be implemented?.
VK4MU MicroController Units
MicroBlocks
Posted: 11:50am 14 May 2012
and a "resume next" please.
When the MM has to work unattended maybe a restart when it crashes, or unrecoverable error, like a 'reboot'.
A flashable 'reboot on failure' to make it configurable?
