Local Time 08:52 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : [MM] 3 bit colo(u)r MaxiMite
     Page 1 of 4
donmck
Posted: 11:09am 18 May 2012
http://www.quantenbit.de/#/teach/Technical/electronics
http://hackaday.com/2012/05/18/a-color-maximite-for-glorious -3-bit-basic/
Cheers Don...
https://www.dontronics.com
jman
Posted: 11:53am 18 May 2012
Hi
This looks really interesting
I think i might just give it try wih a mini
Posted: 04:48pm 18 May 2012
Lads, Lassies,
I wonder if there is much of a performance loss with color enabled?
I assume it reduces the amount of program space and the internal ram drive but it looks great from the little bit I have seen so far is great...
Now to read the articles in full detail.
Nick
Posted: 08:31pm 18 May 2012
That's brilliant!
I can see a Maximite 2 coming up!
So, if I'm seeing it right...
A small mod to the existing MM and the rest of the mod is a firmware update which provides 8 colors from the Video Driver?
If that's so, is there still spare cycles to add sprite support?
Nick
Posted: 09:49pm 18 May 2012
I had a look but can't see details of what changes were made and what effect they have (such as on memory available).
Did I miss them / anyone know more?
JohnEdited by JohnS 2012-05-20
djuqa
Posted: 10:07pm 18 May 2012
Tonights Project will be to hack/modify/adapt/convert 1 of my maximites.
Photos and description will be posted when done.
VK4MU MicroController Units
Sumit
Posted: 11:58pm 18 May 2012
I didnt find any supporting documents or modified/new commands to manipulate colours. Did I miss anything ??
Sumit
djuqa
Posted: 12:01am 19 May 2012
The 1st page linked to in don's original post has the modded schematic and also has a link for downloads of the modded .HEX files.
N.B. The schematic / Files are for the ORIGINAL Maximite and Clones.
Edited by djuqa 2012-05-20
Gadget
Posted: 12:20am 19 May 2012
it took me a minute or two to see the changes
the mod to the circuit involves adding two 120ohm resistors and two diodes from pins 51 and 32 of the pic and the other end going to pins 3 an1 of the vga connector
vasi
Posted: 04:05am 19 May 2012
@Gadget wants to say that modifications are sketched directly on the "ORIGINAL" Maximite schematic.
Elvish name: Mablung Miriel
Beyound Arduino Lang
Posted: 12:42pm 19 May 2012
This was developed by Dr Kilian Singer in Germany. He has a brilliant idea for generating colour which only requires 4 extra components. The speed of MMBasic is not affected and it is backwards compatible with programs written for the standard Maximite.
There will still be some work needed to make it into a working colour MM. Kilian's method will work with a 64 pin chip but it really needs a 100 pin chip (which means a new PCB) and a modified version version of MMBasic. The only issue is that with eight colours you have just 33KB memory left for program and variables - OK for general use but not much for games. However, Kilian has proposed a MODE command so that you can switch between monochrome, four or eight colours enabling you to tune the memory requirement.
It will be interesting to see where this leads to.
Nick
Posted: 12:50pm 19 May 2012
If I were asked what the next enhancement to the Maximite should be, I would have to say the video driver firmware.
If you have only seen the Maximite running on a LCD monitor and not on an old CRT (tube) display, then you will not realise how much better the Maximites 480x432 resolution is on this older technology.
LCD looks c*ap in comparison. On the CRT, every pixel is the same size whereas LCD monitors tend to scale the image to match the panel display or native LCD resolution. Unless you have an LCD which lets you turn this off (very few do), I'm afraid we are stuck with this inferior display with pixels of varying size.
An enhancement to the Maximite video driver firmware should include video output resolution that matches the native panel display of the LCD. This is difficult because there are so many but maybe supporting a few of the most common ones.
A 1024x768 (15" LCD) or 1280x1024 (17" LCD) would be ideal. This lays rise to problems with wide screens which now seems to becoming the norm now.
Fear not! I have a solution!
Whatever resolution is chosen, add "padding" to the video output to fill the unused parts of the display. Effectively create black pixels to make up for the differing screen dimensions. This idea means you could keep the Maximites 480x432 resolution (and keeping compatibility) and, based on a setting that reflects your LCD screens native res, create equally spaced black padding pixels to keep the screen happy and the Maximite's image centered and correct aspect ratio.
And (to bring the topic back to colour) also add colour as we've seen here, although this does involve a hardware hack to implement and so may not become commonplace enough.
jman
Posted: 06:31pm 19 May 2012
Hi
I have done the hardware mod to a Maximite and I now have a Maximite that can
Draw circles and lines in color
I assume they are or will be a command the will let you set the text color?
Maybe something like Font #nbr, scale, color
If I set the Maximite to composite video out it still works
but the video is cutoff on the left by about 10 characters
Edited by jman 2012-05-21
Nick
Posted: 10:10am 20 May 2012
Good work. Now Geoff (or someone) needs to write and submit an article for Silicon Chip that outlines the mod clearly for Maximite users to implement.
The more modded Colour Maximites, the greater the chance of seeing colour software written. Maybe even a colour version of MaxMan.
Nick
MicroBlocks
Posted: 12:20am 21 May 2012
Would that not mean that the "pixel rate" of the vga signal has to be higher, therefore having less cpu time for the program?
Edited by TZAdvantage 2012-05-22
Sumit
Posted: 03:41am 21 May 2012
  jman said   Hi
jman: Good to know that it works for you. What "colour" specific commands did you try ??
Sumit
jman
Posted: 09:29am 21 May 2012
@Sumit
The circle and line commands allow you to set the color
CIRCLE ( x, y ) ,r [,c [,F]] Setting the value of c from 0 to 9 will change
the color of the circle
Nick
Posted: 03:34pm 21 May 2012
Is it possible to rewrite the video driver firmwareto output the sepaate VGA (RGB) signals via 3 available I/O pins?
The idea is to have a plug-in colour option that doesn't require modding of the Maximite in that way, offering a colour option for more people. The more people who have access to colour, the more likely software will be written for it. Everyone already has a colour VGA monitor, adding colour to the Maximite is the missing link.
Nick
jman
Posted: 04:03pm 21 May 2012
@Nick
The hardware mod is to difficult to do
So I think a lot of users could go color real quick and easy
I can post some pics of the mod if you like
Next step a new PCB or a new PCB with 100 Pin version
MicroBlocks
Posted: 10:10pm 21 May 2012
I am busy with something that might work, it uses double buffering so it would be great for making games.
What would be the minimum resolution/color depth and frame rate that would be acceptable?
My personal goal is 800 x 480 16 colors and because no games are needed for it a framerate of 1 would be enough.
     Page 1 of 4
