Local Time 08:05 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Windows Serial Port Driver
lizard
Posted: 04:09pm 18 Jun 2012
Hi All
I am new to this so looking for some help.
I have a duinomite standard board which came with ver 2.7 of the firmware, I have also downloaded tera term, upgraded the driver as described and all was well until I upgraded to ver 3.2c of the firmware.
Now my windows 7 on my pc and vista on my laptop does not want to recognize the driver to allow tera term to see the board.
Anyone have any idea what the problem is?
donmck
Posted: 06:05pm 18 Jun 2012
  lizard said   Hi All
Hi Len, this means basically you just turned the DuinoMite into a MaxiMite, so you need the MaxiMite serial drivers.
see:
http://www.duinomite.com/duinomite-firmware-update-guide/
for a step by step rundown on how to go about this procedure, however I am sure all the information will be available from Geoff's page at:
http://geoffg.net/maximite.html
Good luck with it.
Don...
https://www.dontronics.com
lizard
Posted: 04:28pm 19 Jun 2012
Thanks Don,
I have installed the firmware (DM-1-4-2012d.hex) and installed drivers, I can now use tera term again.
Cannot switch to drive b: is this normal? Edit, ignore this, found out how to do it.
I also have the olimex mod rtc, where can i find how to use this, lots to learn.
CheersEdited by lizard 2012-06-21
donmck
Posted: 07:50pm 19 Jun 2012
  lizard said   Thanks Don,
If you are using the DM firmware, then the RTC should fire up when you get into "setup" and set the parameters correctly.
Don...
