Local Time 08:05 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Want very very cheap prebuilt micro board
Posted: 11:24pm 29 Jun 2012
What's the cheapest board anyone knows?
Needs to be commercially available, don't need many I/Os or a fast CPU. Price is to include the essential parts (CPU, xtal, PCB, etc) and pre-built.
Let's say that even the Olimex PIC32-Pinguino-MX220 at 9.95 euro (about $12 or £8) is too expensive, so what's cheaper?
muddy0409
Posted: 02:52am 30 Jun 2012
Boy, you're a bit hopeful aren't you??
Don't poo poo conspiracy theories.
Remember that everything ever discovered started somewhere as a theory.
vasi
Posted: 03:02am 30 Jun 2012
If you need it only as a reference and you still need to specify the microcontroller...
If is an 18F, see here: jaluino bee
The cheapest one is the one you make yourself if you have already the required parts. Otherwise, you can buy only the pcb from seeedstudio.
Elvish name: Mablung Miriel
Beyound Arduino Lang
DuinoMiteMegaAn
Posted: 06:55am 30 Jun 2012
DIY "Do it yourself" PINGUINO32
Only when the Pinguino team completes everything for this board.
BTW ... Lets not forget about the PICAXE and the Basic Micro Nano 8.
Dirt cheap 8 bangers. Edited by DuinoMiteMegaAn 2012-07-01
isochronic
Posted: 04:50pm 30 Jun 2012
I'd suggest a "smart card" , using a smallish
pic (I think). Futurlec have one at ca $1.30.(?)
$12 each ? There would have to be many, many sold
for any worthwhile return.
djuqa
Posted: 05:16pm 30 Jun 2012
AVR AtMega48 Dev. Board $12 on ebay posted to AussieLand
VK4MU MicroController Units
vasi
Posted: 03:24am 01 Jul 2012
I think this is a good choice
http://www.sparkfun.com/products/10807
Right now, www.picaxe.com is down but there is a good source - is in your country and it can be cheaper...
Otherwise, you need first a programmer for your microcontroller of choice.
With help from friends from this forum I started with a picaxe08m, then I continued with a pic12f675, a serial programmer made with 2 transistors and Jal language. Destroyed 2 other microcontrollers and started saving for a pickit2 programmer - it was the best decision but not the best selection of the online market - got it three times expensive than usual on Romanian market.
Atmel have great microcontrolers but not for beginners - is too expensive to start with (including failures caused by wrong fuse configuration).
Posted: 06:29am 01 Jul 2012
So that's a couple at $12 (£8) pre-built. Lower?
I had no luck finding anything lower from Futurlec, so don't think they do unless I missed it.
Please, only pre-built complete (i.e. populated with CPU, xtal etc) boards. DIY is out.
DuinoMiteMegaAn
Posted: 08:24am 01 Jul 2012
The best and lowest cost microcontroller development board with debugging (emulator) is by far the TI MSP430G value line LaunchPad Development Kit for $5.00 USD.
BTW... JohnS - Google works for me
crackerjack
Posted: 04:42pm 01 Jul 2012
I second the TI Launchpad option at $4.30 delivered (worldwide) - each Launchpad comes with 2 x 16-bit microcontrollers, a USB cable, free download of software, and emulation built in. You can hardly go wrong. I have a batch of them at home and even if I just use them as LED flashers, it's still about as cheap as buying and hooking up a 555 and a couple of LED's. They are ultra-low power devices so really useful for battery powered applications. Coding for them in C is a little tricky - only because they have a squillion peripherals that need setting up in an arcane kind of way, but there is a free software tool called GRACE from TI that helps with that part.
I can't recommend the TI deal highly enough... but of course the old YMMV disclaimer applies and also, I have no affiliation with TI whatsoever.
djuqa
Posted: 05:37pm 01 Jul 2012
Ti launchpad is out of Stock
"Please contact us for an estimated ship date." on ti.comEdited by djuqa 2012-07-03
Posted: 11:21pm 01 Jul 2012
Thanks. I didn't know about that cheap MSP430 board.
DuinoMiteMegaAn - I googled endlessly but most people seem to think very cheap is $99 or $49. What search terms did you use?
I also found (clones of) the USBASP but anyone know whether they can be reprogrammed?
There used to be a $3 PIC10F... board but seems no longer.
vasi
Posted: 03:01am 02 Jul 2012
According to this, there is an Arduino like IDE but you need to have bigger micros than the ones provided in launchpad.
Somehow, is a worthy investment for both educational and pro. areas.
Gettig Started Edited by vasi 2012-07-03
DuinoMiteMegaAn
Posted: 09:28am 02 Jul 2012
Try this "world's lowest cost microcontroller board"
This will point to TI and indirectly to the LaunchPad on TI web page.
The LaunchPad is 16 bit with a full development system. It can't be beat anywhere
at any price. Like CrackerJack, I also own "5 boxes" of LaunchPads in my lab.
BTW ... In the LauchPad kit they give to two microcontrollers. Subtract the price
of one microcontroller and the price drops to $2.00 USD <---- unbelievable
Get this ******* 1.58 euro.******* Better stock up. Edited by DuinoMiteMegaAn 2012-07-03
djuqa
Posted: 01:34pm 02 Jul 2012
You do realise it is HEAVILY subsidised at that price.
elproducts
Posted: 05:22pm 02 Jul 2012
  vasi said   According to this, there is an Arduino like IDE but you need to have bigger micros than the ones provided in launchpad.
Gettig Started
Vasi,
I don't know how you find this stuff. Thanks for sharing.
I didnt even know this existed.
www.elproducts.com
DuinoMiteMegaAn
Posted: 05:25pm 02 Jul 2012
Absolutely, but it really doesn't matter - that's why I got five LauchPad boxes. Once you got the board (emulator) then thats all you need. TI has been "heavily" subsidizing, this LaunchPad product for the last two years and they are NOT going out of business. They have deep pockets.
elproducts
There are the CHIPAXE boards at Howtronics.com .
8-pin to 28-pin.
Use internal oscillator.
Plug directly into PICkit 2.
www.elproducts.com
DuinoMiteMegaAn
Posted: 05:29pm 02 Jul 2012
Still can't beat the 16 bit MSP430G LaunchPad for "about" $5.00 USD
djuqa
Posted: 05:30pm 02 Jul 2012
5 - No wonder they are out of stock Edited by djuqa 2012-07-04
