Local Time 08:05 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problem with binary I/O in MMBasic DOS
Mal_M
Posted: 01:46am 02 Jul 2012
Firstly, a big thank you to Geoff for porting MMBasic to DOS.
I thought I'd try using the DOS version to do some of my file I/O code development (as my target system is hooked up to a bunch of external hardware in the shed, and it's getting a little too cold here in Melbourne to work out there at night)...
I am trying to use the following code to read from a binary file using v3.2C of MMBasic for DOS:
ctr = 0;
do while not eof(#1)
a = asc(input$(1,#1))
print a
ctr = ctr + 1
loop
However, when it reaches the hex value of 1A in the input file, it falsely triggers an EOF condition, and the loop terminates. If I delete the EOF test, I can read past the hex 1A value. But I still get an error (I get a byte sequence of 00 and 00 then the correct values in the remainder of the file).
When I run the same code on MMBasic v3.2A on my UBW32, there is no error. So the problem seems to be specific to the DOS version. I know CTRL-Z (hex 1A) is EOF in some operating systems. I assume that is what is causing the problem here.
I found a related problem when I ran the following test code posted by Geoff here on v32.C of MMBasic for DOS
10 OPEN "chartest.dat" FOR output AS #1
15 FOR i = 0 TO &HFF
20 PRINT #1, CHR$(i);
25 NEXT i
30 CLOSE #1
35 '
40 OPEN "chartest.dat" FOR input AS #1
45 FOR i = 0 TO &HFF
50 IF ASC(INPUT$(1, #1)) <> i THEN ERROR
55 NEXT i
60 CLOSE #1
The above code writes a spurious hex 0D to the output file before the intended hex 0A. Similarly, when the above code throws an error when reading the file back in.
Does anyone have a workaround for this?
Posted: 08:34pm 02 Jul 2012
Unfortunately this is caused by DOS and/or the I/O libraries used by the compiler. The core of the problem is that DOS treats CTRL-Z as EOF. I will have a look at it but I cannot set a deadline.
The extra carriage return should be easier to fix.
This is why writing for Windows (and even DOS) is such a pain... there are secret things going on inside the operating system that will trip you up.
