Local Time 08:05 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : [DM] Power On vs. Reset on eMega...
amadeus
Posted: 07:11pm 09 Jul 2012
Hi all,
I'm new on Duinomite eMega. (and a newbie in PIC32 too) I play with MPLab in C, the Maximite linker, the USB Bootloader.
I observe a difference between :
- DM start after power on
- DM (re)start after reset (button)
...when dealing with the Flash (AT45DB041 on board and not the AT45DB161 like written on the schematic pdf by Olimex) trought SPI. (in main, I do a simple write then read, and it doesn't work properly).
I try several times.
Is it normal ?
Thank you
Edited by amadeus 2012-07-11
