Local Time 05:46 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Rotary Encoders
steveizett
Posted: 02:20pm 11 Sep 2012
Hi Guys
Has anyone implemented reading a Rotary Encoder on the Maximite.
I dont have time to try and work it out. Just want to pinch an existing tried and tested setup.
Steve Izett
boss
Posted: 04:24pm 11 Sep 2012
Hi Steeve,
yes, I did it with ENC128 optical encoder from Bourns long time ago. It was pretty simple task just few lines of code. Here is the "Test code".
Setpin 31 , 6 , L001
Setpin 32 , 2
P = 0 : M = 80 : N = 15000 : V = 0
If P > M And P < N Then Sound P , 200
L001: ' CW
V = Pin(32)
If V = 1 Then P = P + 1 Else P = P -1
Print " " ; P ; " " ; Chr$(13);
Ireturn
boss
steveizett
Posted: 03:19am 13 Sep 2012
Thanks Boss
Being optical I guess that contact bounce is not an issue.
They appear much more expensive than the mechanical contact variety.
So I could use the mech version I have and use either hardware debounce or put some delay into the read of pin 32 which is not so good in an ISR.
Steve Izett
boss
Posted: 04:52am 13 Sep 2012
Hi Steve,
I choosed the optical one for resulution 128 pulses/rotation and I was also tested the mechanical one with 32pulses/rot. If I remember well, I used 4k7 resistor to Vcc and multilayer capacitor 2M2 (2.2uF) to GND. The optical one was on Ebay around $10 which is not bad.
boss
steveizett
Posted: 10:32pm 13 Sep 2012
Hi Boss
I used the mechanical encoder I had with some hardware debounce and she works like a beaut.
Thanks very much.
Steve
boss
Posted: 04:34am 14 Sep 2012
Hi Steve,
nice to hear that. If you don't mind please publish the details about debouncing for others. Most people include myself are looking here before they started a project.
boss
steveizett
Posted: 05:04am 14 Sep 2012
Altronics S3350 Rotary Encoder $4.50 - 20 pulses/360deg
Setup as follows:
Common to 0v
Two outputs via 4K7 to Vcc (3.3v) and 104 caps to 0v
I'm using the D0 & D1 inputs on the Colour Maximite.
Functions flawlessly with normal rotation of the encoder.
When rotated very quickly (beyond normal use) it fails to read.
I haven't checked how noisy the outputs are on my CRO at this stage.
Code, pretty much identical to that listed by Boss earlier in this thread except interrupt triggered on negative going pulse.
Steve Izett
boss
Posted: 05:19am 14 Sep 2012
Hi Steve,
this corresponds with my earlier tests. I used inexpesive ebay product 32pulses/360deg.
I experienced the same difficulties use encoder at excessive speed. That's why I increased capacitors value. Inreasing the capacity beyond 2.2 uF gives no further improvement. The best cap value will depend on particular encoder you have to tray it.
boss
