Local Time 04:53 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Arduino X
vasi
Posted: 10:15pm 18 Sep 2012
Somebody knows about Arduino X board? It seems that is a board equipped with Atmel ARM microcontroller as Arduino Due. Atmel is reffering it in ASF (Arduino Software Framework) documentation.
Elvish name: Mablung Miriel
Beyound Arduino Lang
ronee
Posted: 12:31pm 20 Sep 2012
  vasi said   Somebody knows about Arduino X board? It seems that is a board equipped with Atmel ARM microcontroller as Arduino Due. Atmel is reffering it in ASF (Arduino Software Framework) documentation.
Some pics here
http://www.flickr.com/photos/robotgrrl/sets/7215762985544407 6/
Ron
djuqa
Posted: 12:33pm 20 Sep 2012
Thanks Ronee
Clickable linkEdited by djuqa 2012-09-21
VK4MU MicroController Units
vasi
Posted: 03:30am 21 Sep 2012
Yeah, probably identical with DUE, but different microcontroller. Atmel refers at those as separate boards, DUE and X.
graynomad
Posted: 04:48am 22 Sep 2012
I don't know where the X comes from but that board is a Due with a SAM3X8E, as has been the case for some time.
EDIT: Originally the Due was going to use a different SAM3 (the U I think), maybe the X refers to what was going to be a second version using the X8E but they have since been merged.
______
RobEdited by graynomad 2012-09-23
Rob Gray, AKA the Graynomad, www.robgray.com
vasi
Posted: 10:59am 22 Sep 2012
That may be the case, thank you guys!
graynomad
Posted: 02:37pm 22 Sep 2012
It's interesting to see that Atmel is officially supporting Arduino though. One school of thought over in Arduino land is that Atmel pressured them to swap processors so they could show off the new X8E, but the chip is still not readily available and that's why we're seeing such a delay with the Due.
______
Rob
ernie
Posted: 02:44pm 24 Sep 2012
What ever happened to the Arduino Due? They handed out 100 of the first batch to developers back in May, then nothing, not a peep about it since.
graynomad
Posted: 05:15pm 24 Sep 2012
Word (well rumour) is that it may be released at the NY Maker Faire in a few days on the 29th. After all this time though people are very sceptical.
______
Rob
djuqa
Posted: 05:38pm 24 Sep 2012
It may have to be renamed the Arduino OVERdue
graynomad
Posted: 09:25pm 24 Sep 2012
he he, yep I used that line a while back on the Arduino forum :)
It's certainly taking an unDue amount of time.
____
Rob
elproducts
Posted: 11:52am 01 Oct 2012
Arduino DUE announced at Maker Faire New York.
$49.00 available October 22.
ARM based.
Youtube video below.
It's about an hour long.
One of the more interesting topics is at the end when he talks about open source.
http://www.youtube.com/watch?v=4TZQt9lTAOU
www.elproducts.com
graynomad
Posted: 12:13pm 01 Oct 2012
[quote]It's about an hour long. [/quote]
Ooo, bit long for my data plan :)
I gather there was nothing of substance, ie. real details about features, the new IDE etc. Is that the case?
_____
Rob
elproducts
Posted: 12:56pm 01 Oct 2012
They talked about changes to the IDE that it will make it easier to add other compilers and platforms to the IDE but I'm not sure what they meant as they didn't go into much detail.
I assume they mean the IDE can be modified to support chipKIT, netduino or other arduino style modules but don't know for sure.
They also mentioned that a version of DUE would have internet embedded in the module with a future release chip. Again not much detail.
They had the designer of the Atmel AVR talk but I fast forwarded through that as it appeared to be an Atmel commercial rather than an Arduino update. That took about half the time.
www.elproducts.com
graynomad
Posted: 01:14pm 01 Oct 2012
Thanks, that's a lot more info than has been posted on the Arduino forum so far.
______
Rob
DuinoMiteMegaAn
Posted: 06:04am 02 Oct 2012
One point that Massimo Banzi stated is that a user can take a 8 Arduino AVR application and recompile it for a 32 bit ARM Due application and it will work. This would be an incredible amazing feat if it really does indeed work? No wonder
why there was a delay of one year releasing the hardware - software was probably the cause of this delay?
Also, the price of $49 USD is 1/2 what I expected for a 32 bit ARM board. Edited by DuinoMiteMegaAn 2012-10-03
elproducts
Posted: 11:17am 02 Oct 2012
chipKIT takes a file for the 8-bit Arduino and programs a PIC32 so its been done before, just not for ARM.
chipKIT is almost 1/2 that price at $26.95 so it seems a bit high to me. The cost of a 32 bit vs 8 bit is not that big of a difference that it should be $20 more than the standard Arduino. There must be more to the story which may help explain the year long delay.
It should be interesting to see all the details when its released.
www.elproducts.com
DuinoMiteMegaAn
Posted: 12:07pm 02 Oct 2012
If you consider the chipKit board, when it first came out, Diligent hardly had any workable libraries for their 32 bit PIC board. It took them forever and not all the Arduino libraries are ported. Leaflab's "Maple" tried and failed to port all the Arduino libraries to their 32 bit STM ARM chip. Maybe the italians can do better job on their "first" try in releasing their 32 bit DUE ARM?
BTW ... there is a 32 bit ARM board via Kickstarter and it is called Teensy 3.0 for
$26 USD. The project's author is now porting the Arduino libraries for this "Arudino non-form factor" 32 bit ARM (Freescale) microcontroller stamp. Software quality is always the key in any project completion or failure. Edited by DuinoMiteMegaAn 2012-10-03
vasi
Posted: 12:21pm 02 Oct 2012
Indeed that was a stupid idea to release the board (ChipKit) without examples and library support. They lost a lot of potential customers that way. Maybe they will start to regain some of them when all the software and libraries will be completed.
Ha! They expected community to jump in and start developing libraries for the board!!! How to do that when the majority (let's remember that those kind of boards are designed for artists and students) didn't knew what was that PIC32 thing (me included)???
If Due is delivered with all the libraries and examples (at least, the same as the official Arduino AVR) then, my hat off.
elproducts
Posted: 01:41pm 02 Oct 2012
  DuinoMiteMegaAn said   If you consider the chipKit board, when it first came out, Diligent hardly had any workable libraries for their 32 bit PIC board.
Good point. Maybe thats why they said there were so many changes to the IDE but couldn't really detail it. It involved modifying the compiler.
www.elproducts.com
