Local Time 04:53 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Inkey$ in large loop
pcaffalldavis
Posted: 04:48am 27 Sep 2012
I have a large loop program to run my boiler. It is time to add menus and start adjusting variables without having to reboot.
The MM program monitors the boiler. When the firebox air intake is open for 15 min and the water temp does not go up it means the fire is out. If the fire is out the air intake closes and the combustion blower turns off. As long as the fire remains out (FIRE=0)the boiler won't try to reopen the air intake and start the blower to raise the water temperature regardless of how cold the water temperature gets.
I added a program line just before the end of the main loop: FIRE$=INKEY$, and the next line: IF FIRE$ <> "" THEN END
The program does not end when I press any key on the keyboard (except Control +C). It keeps going even when I hold down any key continuously for the whole loop.
First I tried using the Y key with IF FIRE$="y" OR FIRE$="Y" THEN FIRE=1. This would let the program know I built and am lighting a new fire, which is what I want to do without having to reboot. But, as I've noted, Inkey$ does not seem to be trapping my keyboard input.
Why is Inkey$ not trapping my keyboard input?
I'm running MM version 2.7B on this bench unit.Edited by pcaffalldavis 2012-09-28
We're all here 'cause we're not all there.
BobD
Posted: 07:56am 27 Sep 2012
You could try replacing THEN END with a GOTO line number and at that line number have an END command.
1000 FIRE$=INKEY$
1001 IF FIRE$ <> "" GOTO 9000
9000 END
pcaffalldavis
Posted: 10:08am 27 Sep 2012
Okay, I had an snippet just before the LOOP command that pointed at the LOOP line number thereby skipping over the newly installed Inkey$ lines just before the LOOP line.
Problem solved.
Thank you!
