Local Time 04:53 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Have you come across this serial protocol
steveizett
Posted: 01:54pm 28 Sep 2012
Hi Guys
I've got some equipment that talks between modules using standard 19200 serial.
I want to mimic some of the data using the maximise display.
Is the protocol below a standard one and is there standard code formation for working with it?
I'm just learning to write code in Basic and never been very good at writing code!
Commands are always sent as 1 serial word with bit 7 set.
All Data bytes are sent as 2 serial words. The first word is the 7 lsbs of the data byte (bit 7 clear) The second word will contain the msb of the data byte in bit 0 (all other bits clear)
Thanks for the help.
Steve Izett
VK2MCT
Posted: 08:54pm 28 Sep 2012
Could this be an old octal orientated protocol ?
Six bits in the first word (two octal bytes) being DEC Sixbit ASCII.
The second word being one bit of parity ????
John B
VK2MCT
boss
Posted: 07:39am 29 Sep 2012
Hi Steve,
this protocol is a little strange, but why not? I assume that the data is a binary 8 bit long code, bits 0-6 are sent in the first byte, and bit 7 is bit 0 in the second byte. It is a weird configuration but easy to read and use. Is there any way I can help you with it?
boss
steveizett
Posted: 11:33pm 29 Sep 2012
Thanks John
Thanks Boss
Thanks for the offer.
How about the following code!
How do I set a Flag and invert it like the ! operator in C.
DO WHILE INPUT$(1,#1) <> &hF0 :LOOP 'Command is 8th bit set
MSB = TRUE 'Data is going to come down the pipe MSB followed by LSB
FOR i = 0 To MAX
arg(i) = &h00 'Clear table data ready for new data
DO
x$ = INPUT$(1,#1)
IF MSB THEN 'If its the MSB then store the data word in the Table
arg(i) = x$
ELSE IF NOT(MSB) AND x$ = &h01 THEN 'if its NOT the MSB AND its got its bit0 set then add 80h
arg(i) = arg(i) + &h80
NOT(MSB) 'Reset MSB flag
LOOP
NEXT i
LOOP
Steve
steveizett
Posted: 03:22am 30 Sep 2012
Hi Boss
I did a little more work on the code. See below:
I think I have a problem with data types. Should I be working with a string or does it need converting
to work with raw numbers.
Cls 'Clear the screen
Open "Com1:19200" As #1 'Open a 19200 baud Serial Port
Dim arg$(32) 'Set up a table for the data
Do 'Main Loop
If Loc(#1) <> 0 And Asc(Input$(1,#1)) <> &hF0 Then 'If Data is present
MSB = 1
For i = 0 To 31
arg$(i) = ""
x$ = Input$(1,#1)
If x$ = "255" Then
Exit Sub 'End of data so return
EndIf
If MSB = 1 Then
arg$(i) = x$
Else IF MSB = 0 And x$ = "1" Then
arg$(i) = arg(i) + &h80
EndIf
If MSB = 1 Then
MSB = 0
Else MSB = 1
EndIf
Next i
EndIf
Posted: 04:05am 30 Sep 2012
The equivalent of C's ! is just:
x = 1 - x
(so long as x is already the equivalent of C's true or false)
steveizett
Posted: 12:41pm 30 Sep 2012
Thanks John
Appreciate it.
Steve
