Local Time 02:21 07 Aug 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : UBW32 Boot Problems.
Posted: 07:19pm 14 Oct 2012
Hi All,
Just thought I would share an experience I had with my UBW32.
From the day I got it it was always a bit clunky on power-up.. sometimes it would be powered for about 5 seconds before I got life out of it then you would hear Bong Bing and windows would detect it. Same if I set an AUTORUN.BAS to flash an LED. Not a big deal but as development of my UBW32-MCC PCB progressed I noticed that it was becoming a bit erratic... once operational it never failed but resets and power ups were very hit and miss..
I checked the Schematic and saw that there was a 10uF capacitor (C5) connected to VCap and remembering that the original MM needed a capacitor change I piggy backed another 10uF (scavenged from an early DM prototype) on top of C5 and bingo.... No more problems
Power Up and Reset 100% of the time.
Something to store in your memory banks
jman
Posted: 10:04am 09 Nov 2012
Hi Mick
Thanks for the tip.
I have 2 UBW32's and one of them would not boot with either bootloader.
I replaced the 10µf with a ceramic one (as used on the Colour Maximite)and the problem is solved.
aargee
Posted: 10:57pm 09 Nov 2012
My UBW32 has just gone through a patch of lockups and/or no boots. The original designer had specified a SOT23 version of the LM317 regulator for both the +5V regulation and the 5V-3.3V regulator. For the 5-3.3V the regulator is outside its Vin-Vout tolerances, so I swapped it for a low dropout LM1117 and that solved the problem. I also removed the onboard fuse and replaced it with a link.
- Rob.
Posted: 12:09pm 10 Nov 2012
  jman said
Thanks for the tip.
I replaced the 10µf with a ceramic one and the problem is solved.
Great to hear John,
I was a bit surprised as a Google search found not many people having trouble with the UBW32 not starting.
