Local Time 04:06 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Maximite GUI
3buns
Posted: 12:04am 06 Nov 2012
Hi all, would experienced users of MMBasic be able to comment on a rather ambitious project I have for the Maximite (B&W)?
I'd like to be able to have a simple text UI, driven by an old school serial mouse, I would also like to bit bang midi. Do users think the Maximite has enough horsepower to perform all three simultaneously? I guess the MIDI routines would have priority, the GUI and mouse would have to 'catch up'. Esential I would like to create a very basic MIDI sequencer.
Kind regards, Kurt.Edited by 3buns 2012-11-07
Nick
Posted: 09:07am 06 Nov 2012
That would be great! The Maximite would make a nice compact MIDI controller and the onboard SD card could hold songs for live performances.
I assume the MIDI drivers would need to be written in assembly language since BASIC may not be fast enough?
Why a text GUI? Design your Graphic GUI layout on a PC/MAC and LOADBMP the entire screen with one command. Instead of a mouse, a well designed GUI can be had that utilized the function keys.
Nick
3buns
Posted: 11:32pm 06 Nov 2012
Hi Nick, I was going for the text UI as I thought it might be quicker to refresh parts of the screen that need updating, such as the track timelines. I was also going for a mouse as I would like to have say 8 favourite instruments in a tool bar that I can drag and drop on to any one of the tracks.
I'm afraid I haven't written assembler since the original 8 bit PICs in the 90s, I'm going to try some code at the weekend and try using the PULSE command, the manual says its good for +/-1uS, which is outside the 1% for midi accuracy, but I'm going to try it on my Yamaha QY70, just to satisfy my mind first.
King regards, Kurt
3buns
Posted: 12:11am 07 Nov 2012
Actually, I've just realised that program execution speed will hold back the bit banging, I will need to implement MIDI messages another way. Back to the drawing board.
Kind regards, Kurt
jdh2550
Posted: 12:42pm 07 Nov 2012
  3buns said   Actually, I've just realised that program execution speed will hold back the bit banging, I will need to implement MIDI messages another way. Back to the drawing board.
Kind regards, Kurt
Do you have any experience programming in C? If so, it's relatively easy to add commands to the interpreter and have C level routines handle the bit banging. Would that work for you? (it's how we did the CAN commands)
3buns
Posted: 10:10pm 08 Nov 2012
I don't know any C, but am always willing to learn something new. My next thought had been to use a couple of cascaded off-board PISO shift registers, I could then get the timing spot on but would have to waste the last 6 bits of the message.
Cheers, Kurt
