Local Time 03:02 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Yet another version of MMBasic (ver 4.0B)
Posted: 05:03pm 10 Nov 2012
In a brilliant bit of work TassyJim found the bug that caused XModem transfers to fail in V4.0 of MMBasic.
I have implemented the fix in V4.0B which can be downloaded from http://geoffg.net/maximite.html
Thanks Jim,
ajkw
Posted: 11:31pm 10 Nov 2012
From the changelog 4.0a
When using the RUN, SAVE or LOAD commands quote marks are no longer required
around the file name. They are still required if the command is used within a program.
This is a most welcome improvement!
Cheers,
Anthony.
