Local Time 02:10 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Rs 232 / 115200 baud
plasma
Posted: 11:14pm 30 Nov 2012
Ive testet 115200 baud on the duinomite with no luck.
57600 baud runs fine , 115200 give me wrong strings such like xxxxxxxx
Have anybody testet the maximite with this baudrate ? Maybe its only on duinomite ?
Greg Fordyce
Posted: 05:54am 01 Dec 2012
MM/CMM can only do 19200 baud, for higher rates you have to use the Duinomite. Why it's not working for you, I don't know, I only have a MM & CMM.
CircuitGizmos
Posted: 06:01am 01 Dec 2012
Isn't 115200 specific to com3/4 only? Are you using com1/2?
plasma
Posted: 01:00pm 01 Dec 2012
hi ,
i use
open "COM4:57600,2048" as #1 <-works
open "COM4:115200,2048" as #1 <--- false
Posted: 03:03pm 01 Dec 2012
  plasma said   hi ,
i use
Hi Plasma,
At that sort of speed I would expect that you might/would need some form of handshaking in effect.. CTS/RTS handshaking is hardware. XON/XOFF is software
I haven't used RS232 on any `mite so I cant be more helpful.. sorry.
vk4tec
Posted: 07:53pm 01 Dec 2012
Serial comms is implemented in bit bang and hardware UART on some of the mites.
I have had no problems running PIC at higher speed in assembly.
Can I ask is there any reason why you need such a high speed ?
- Andrew -
Andrew Rich VK4TEC
www.tech-software.net
plasma
Posted: 01:21am 02 Dec 2012
it looks like a real rts/cts thingy ,you are right bigmik.
at vk4tec : ill create a remote control with the multiwii protocoll.
i use the maximite/duinomite for rapid developing.
the remotecontrol is for my quadcopter toy :
http://www.youtube.com/watch?v=POc8vGSmB2M&feature=plcp
it will run on android/ios/win or mac pc.
maximite is usefull to test the remote controll soft/hardware.
