Local Time 02:09 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SD Card and colour maxi
Bill.b
Posted: 04:50pm 03 Dec 2012
Hi All
I have been playing with my new CSCOLORMAXI and have found that
when I remove the SD card and reinsert it the CSCOLORMAXI does not
read the card unles the power is recycled.
is the a problem with the CSCOLORMAXI or both the colour maximite and the
CSCOLORmaxi or the type of SD card i am using.
This SD card worked OK the my old maximite without and problems.
SC Card - Lexar SDHC Platinum II 8 gig
Bill
Posted: 06:14pm 03 Dec 2012
Hi Bill,
Without a cct I cannot be sure if Rob has designed a card inserted switch on the SD card.
I can assure you though that the Colour MM can and does detect the card is inserted and replaced (it uses a microSD connector).
I tried this on the UBW32-MCC PCB I designed and it indeed worked as expected.
PIC Pins 82 (D5) and 83 (D6) should be GNDed when the SD card is inserted and Not write protected.
Bill.b
Posted: 07:21pm 03 Dec 2012
Hi Mick
The socket for the SD card on the CSCOLORMAXI is a simple design with only the 9 contacts for a standard SD card. It appears that there is no insersion switch or
eject mechanisum.
Bill
