Local Time 02:09 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Sending to serial port without CR LF?
mookster1
Posted: 11:58am 06 Dec 2012
Hi all
I'm currently trying to write a terminal program for my Maximite so that I can operate my screenless and keyboardless miniMaximite with its COM2 port in console mode, over a radio link, using the Maximite's serial port (which has a screen and keyboard plugged in.) Currently I have it so that it uses INKEY$ to store one byte from the keyboard in char$, then it uses PRINT #1, char$ to send it over COM2.
The issue I am currently having is that the PRINT #nbr command sends the character to the serial port, but it's also sending CR/LF to the serial port as well, so I can't actually type a command! Is there any command I can use to send a character directly to the serial port without this occurring?
Cheers!
Capacitance is futile - roll on 2012!
Greg Fordyce
Posted: 12:25pm 06 Dec 2012
Use a semicolon at the end of the print statement. More info in the manual.
Greg
CircuitGizmos
Posted: 12:28pm 06 Dec 2012
PRINT #1, char$;
I have not tested this on a serial port, but I understand the semicolon suppresses the CR/LF on screen.
Edit: And Greg beat me...Edited by CircuitGizmos 2012-12-07
mookster1
Posted: 01:33pm 06 Dec 2012
Thanks for that, I can't believe I couldn't find this in the manual! It does indeed do the trick
