Local Time 23:55 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CtlrC enable/disable command
boss
Posted: 12:54pm 02 Jan 2013
Greeting from Vancouver,
I'm testing CMM(UBW32) and MM in an academic enviroment now. An CtrlC enable/disable command is highly desired. I'm wondering if somebody there has the same needs. And I think this is a question for Geoff.
CircuitGizmos
Posted: 12:57pm 02 Jan 2013
I don't have a pressing need for it, but I know I would use it if it were available.
Posted: 02:07pm 02 Jan 2013
Why would you want to disable CTRL-C?
It is automatically disabled when there is an XMODEM file transfer in progress and other than that all input from the keyboard/USB should be from a human.
boss
Posted: 02:51pm 02 Jan 2013
Hi Geoff,
thanks for quick answer, the MM is an integral part of testing equipments which are controlled by trained operators. They have to fill some kind of forms first before testing starts. If they accidentaly press CtrlC (instead ie. ShiftC) the program stops. Using the "Continue" command does not always work . This happens from time to time and it is really annoying for supervisors.
boss
