Local Time 23:55 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Serial test
vk4tec
Posted: 05:37am 04 Jan 2013
Interesting result
open "com2:4800" as #1
do
print loc(#1) ' print rx buffer size
loop
Gets up to "127" and maxes out
open "com2:4800,2048" as #1
do
loop
Gets up to "255" and maxes out
- Andrew -
Andrew Rich VK4TEC
www.tech-software.net
CircuitGizmos
Posted: 05:46am 04 Jan 2013
Which version of MMBasic is this? 4.2?
vk4tec
Posted: 06:00am 04 Jan 2013
MMBasic Version 4.0B
I have something else intersting.
I am reading from a GPS.
I think the PIC is too fast ( if that is feasable )
If I read two bytes really quickly, sometimes they come out null.
Or one is populated and the second is not.
If I slow down the read with a pause 10, I can get 100% read rate from the com port.
I think I need to check if there are some characters to read first .
LOC(#1)
- Andrew -
Andrew Rich VK4TEC
vk4tec
Posted: 06:05am 04 Jan 2013
not quite sure how to code that one
do while loc(#1) = 0 : loop
- Andrew - Edited by vk4tec 2013-01-05
Andrew Rich VK4TEC
CircuitGizmos
Posted: 06:37am 04 Jan 2013
do
loop
I've duplicated these results on 4.2.
vk4tec
Posted: 07:35am 04 Jan 2013
I did a dumb thing
Threw my GPS from 19200 to 38400 baud
And of course the PIC on this port does not do 38400
Out with the serial port PC
- Andrew -
Andrew Rich VK4TEC
Posted: 12:49pm 04 Jan 2013
255 may be related to the max string size
(though it probably should not be)
