Local Time 23:08 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : audio out .........
hitsware
Posted: 05:30pm 08 Jan 2013
hitsware
Posted: 05:37pm 08 Jan 2013
R14 and R16 should become OPEN ....
R13 and R15 should be SHORTED .....
Posted: 02:55pm 09 Jan 2013
  hitsware said   R14 and R16 should become OPEN ....
Why do you say that?
If you were to do as you say you would change the output to be 0-3.3v (depending on the load you plug into) which as far as I am aware is too high for driving an audio amp..
The circuit as shown should provide a signal that swings between 0 to 0.5V and is a squarewave that is `rounded' by the 2 Capacitors...
Now looking at the design `maybe' (I am no expert here) the swing should be closer to 0 - 1.0v for proper output levels of typically 0.775V RMS..
Also `maybe' the outputs should be capacitively coupled to filter out any chance of DC offsets..
I am no expert on audio stuff and I do agree that the sound level appears a bit low out of the Sound Jack but a decent amplifier works well enough with it.
Maybe Geoff will have further comments here.
EDIT *****
Unless your proposal is for the PWM use of the ports.... which might need a different specification (I have never used PWM and dont know the specifics.. but I am aware of the principals of PWM)
Edited by bigmik 2013-01-11
hitsware
Posted: 05:08pm 09 Jan 2013
I prefer as 'hot' as possible within wanted frequency response
The first LP ......4.7k with ? to ground is enough.
Any load actually weakens the rolloff slope.
Another stage of LP would make sense ..... But not pure attenuation.
BUT ...... I see your point about matching exisiting amps .
FWIW:
http://www.t-linespeakers.org/tech/filters/passiveHLxo.html
Edited by hitsware 2013-01-11
Posted: 03:21am 10 Jan 2013
I am no expert on audio either so I just designed it to be quite loud with the powered speakers that I use. But it is easy to modify, just change R14 and R16.
There is a DC offset on the output but all the amps that I have checked have capacitors on their inputs and, as I was trying to keep the component count down, I figured that an extra capacitor was superfluous.
  Quote  a squarewave that is `rounded' by the 2 Capacitors...
No, that is not quite correct. The output is PWM at about 100KHz so the two capacitors are used to average the PWM signal (ie, remove the 100KHz carrier leaving the audio).
hitsware
Posted: 07:19am 10 Jan 2013
  Geoffg said   But it is easy to modify, just change R14 and R16.
Easy for you .... :) I'll have to look at your SMD article.......
Posted: 01:07pm 10 Jan 2013
Ok Thanks Geoff,
I just looked at the circuit in question and tried to work out what the affect of the two caps would do to the square wave outputs from D1 and D3...
I wasnt really thinkng of the output as PWM... so it is a Low Pass filter then? Hence HITSWARE's reference to LP which I admit didnt click with me what he was saying there.
hitsware
Posted: 03:58pm 10 Jan 2013
  bigmik said  .. so it is a Low Pass filter then?
For sure. I have a DuinoMite that has the audio out jack(s)
wired (I think) direct from the mainchip .... No filter
BUT ! ...:( No stereo ! or dual PWM channels .....
Mr Duino needs to hop on the Music Wagon
Posted: 02:35am 11 Jan 2013
try replacing R7 and R8 with 100uH inductors, and up C15 and C16 to 220nF.
assuming a source impedance of about 40 ohms at the pin, this will produce a
far more pleasing filter effect, flat up to about 10kHz and 20dB down at 100kHz.Edited by robert.rozee 2013-01-12
