Local Time 20:40 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Can you disable CTRL+C break?
Posted: 07:30pm 13 Jan 2013
I know I keep comparing the MM to the Atari 8-bit home computers(such as the 800XL or the 130XE), and MM and the MM BASIC are not Atari's, but...
In the Atari, you could poke a memory location, to disable the BREAK key, preventing the user from stopping the running program. From what I remember, you could also poke another location, that would force a cold-boot if RESET was pressed.(the default on pressing RESET was a warm-start).
Is there any way to stop users breaking into the BASIC program?
I am currently looking VERY closely at CircuitGizmo's little keyboard interface chip thing, as this would allow a custom keyboard to be connected to the MM, effectively preventing the pressing of CTRL+C, but also wondering if there is any other way other then ruling it out via hardware.
boss
Posted: 10:29am 14 Jan 2013
I have the same needs. I'm testing MM in a academic enviroment where MM is an integral part of testing equipments controlled by trained operators. They have to fill some kind of forms first before testing starts. If they accidentaly press Ctrl-C (instead ie. ShiftC) the program stops. Using the "Continue" command does not always work . This happens from time to time and it is really annoying for supervisors.
Posted: 11:11am 14 Jan 2013
OK, I give in. I will put a YAO (Yet Another Option) to disable CtrlC into 4.3 (due out soon). But be warned, without CtrlC the only way to break out of a running program will be to cycle the power.
vk4tec
Posted: 11:52am 14 Jan 2013
Please don't disable Ctrl c. It works fine . Power cycle won't help me.
Andrew Rich VK4TEC
www.tech-software.net
boss
Posted: 12:24pm 14 Jan 2013
no one wants to disable Ctrl-C pernamently. I suggest to add a command "CtrlC disable/enable" which should work for both us.
rambo55
Posted: 01:25pm 14 Jan 2013
Please Do not disable the ctrl cEdited by rambo55 2013-01-15
CircuitGizmos
Posted: 01:41pm 14 Jan 2013
Guys:
This isn't a change that Ctrl-C will never ever work.
It is a BASIC command to turn it on or off.
Something like:
OPTION CTRLC ON
and
OPTION CTRLC OFF
Valid during program run. Put it at the beginning of your program and you cannot use Ctrl-C to break out of that program.
If you don't like it, default is that Ctrl-C works as before.
TinkersALot
Posted: 01:57pm 14 Jan 2013
me thinks Geoffg would be well served to teach some of us to fish inside the mm-code-pool, but to keep the forces of entropy at bay, Geoffg must still be kingfisher among the throng.
CircuitGizmos
Posted: 02:00pm 14 Jan 2013
"Geoffg must still be kingfisher among the throng"
Amen.
MOBI
Posted: 02:12pm 14 Jan 2013
My old (OSI superboard) computer with Microsoft Basic in 8K rom used to have a location in RAM to poke to which could enable/disable ctrl-c.
I wonder, could the poke function be extended to perform the ctrl-c on/off?
David M.
Posted: 02:19pm 14 Jan 2013
An option to disable CTRL+C for the currently running BASIC program would be a real advantage, and if you did the same thing with the Atari(here I go again - sorry!), yes, you would have to reset the computer to get the command prompt back again.
Poke another location, and I am pretty sure you could disable the RESET button too, so that reset or break both would not work, and you HAD to cycle power.
This kind of lockout does not suit everyone, as evidenced by the posts above from other members here shocked at that idea they might lose their CTRL+C, which was never my intention - only to be able to switch it off if you don't want the user to have that ability.
The MM has really become something of a blast-from-the-past for me - so many similarities with the Atari I used to program in about 18 or so years ago...
I just wish my colour one would arrive(ordered on the 4th).
Posted: 02:30pm 14 Jan 2013
WHILE I THINK OF IT - How come MM BASIC does not use the [BREAK] key on the keyboard to stop the program running?
...an ideal key choice, I would have thought...
However, there must be a reason, so I would love to know what that is.
Perhaps as simple as the fact that CTRL+C would have been used in the BASIC that MM is based on? Perhaps this was how you stopped programs running in MS BASIC or GW-BASIC etc back in the day?
...I never programmed in either of these.
CircuitGizmos
Posted: 02:34pm 14 Jan 2013
Ordered from me? 10 days to NZ would be quick. Ship time to NZ is 10 days minimum, 15 days typical.
CircuitGizmos
Posted: 02:39pm 14 Jan 2013
"Perhaps as simple as the fact that CTRL+C would have been used in the BASIC that MM is based on? Perhaps this was how you stopped programs running in MS BASIC or GW-BASIC etc back in the day?"
You are correct.
Posted: 02:41pm 14 Jan 2013
No, but I think I should have.
Altronics in Australia, and I also paid $30 for 3-4 day delivery.
I've emailed them a couple of time to ask what has happened(as they would have the tracking number so I thought), but no answer.
I DID get one reply saying that they sent it on the 4th, and to let them know if it had not arrived by the 11th(which it didn't), so I did let them know, but have not as yet received any reply from them.
While I have your attention CG, and a slight digression, I don't suppose you can connect your PS2 keyboard chip thing to a standard computer?
I would expect not, as your chip obviously generates PS/2 codes fine, but probably would not respond to the PC trying to poll it to see if it has a keyboard connected - I understand that the initial communication between a PC and it's keyboard is relatively complicated...
CircuitGizmos
Posted: 02:45pm 14 Jan 2013
I should just test this and let you know.
Posted: 02:53pm 14 Jan 2013
...and I digress again, but I started the thread, so...
I just see that chip being handy for PC control applications too, where you have a dedicated system. I used to hack a keyboard whenever I needed a custom keyboard.
You CAN get professional custom keyboard things where you can put some buttons on them, but they are very pricy, whereas your chip is nicely priced.
ajkw
Posted: 02:54pm 14 Jan 2013
If I remember correctly the status of the boatloader/update button is available to MMBasic. If so, you could always disable ctrl - c as required but include in your program an interupt on the bootloader button to provide a 'programmed way' to end a program running rather than just cycling the power.
Posted: 03:02pm 14 Jan 2013
Clever idea.
CircuitGizmos
Posted: 04:20pm 14 Jan 2013
No go, so far. Might work in conjunction WITH a keyboard (as it will do on the Maximite) but I have not tested that.
