Local Time 20:39 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Error Checking File access
marcwolf
Posted: 06:26pm 21 Jan 2013
Hi Folks
If I try and read in from a file number that has not been used I get an error. Is there a way I can check this situation and not crash out of the program.
DaveEdited by marcwolf 2013-01-23
Coding Coding Coding..
Keep those keyboards coding..
RAW CODE!!!!!
shoebuckle
Posted: 08:28pm 21 Jan 2013
  marcwolf said   Hi Folks
Dave
I gather that the non-existence of the file is a valid condition, so how about testing that the file exists before trying to read from it and set a flag to say that it exists or doesn't. This will work because OPTION ERROR CONTINUE will trap a non-existent file.
File1=1
OPEN "MyDataFile" FOR INPUT AS #1
IF MM.ERRNO = 6 THEN File1 = 0
OPTION ERROR ABORT
If File1 = 1 THEN INPUT #1, a,b,c
Hugh
