Local Time 16:46 27 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : In the next release of CG’s CMM....
Posted: 02:08pm 30 Jan 2013
Right!
Now that I have CG's attention......
In your next release of the unit, do you plan to keep or get rid of the grid-of-holes prototyping area? Just trying to decide if this is something I can bank on, or something you perhaps have plans to axe in the next version of the PCB...
Perhaps axing it to make the PCB smaller - probably not - it is pretty small now.
I am about to order one from you - I have had enough of the fecking around I am getting from Altronics, as my CMM is still not here...
EDIT: Also, what is U2? (please - no jokes about it being a band!)Edited by Grogster 2013-02-01
CircuitGizmos
Posted: 02:54pm 30 Jan 2013
U2 is 8-18VDC to 5V switching regulator.
The CGCOLORMAX2 will still have the sea-of-holes.
Posted: 03:11pm 30 Jan 2013
Cheers, mate - all I needed to know.
I will order a couple of those keyboard interface chips too.
I will do the order tonight(my time).
MOBI
Posted: 03:22pm 30 Jan 2013
  Quote  I will order a couple of those keyboard interface chips too
OT - but have you thought about designing a pic to do a matrix keyboard? Not too difficult. I have an I2C version of 12 key, 16 key and 32 key keyboards. The I2C could fairly easily be changed to give PS2 output. The I2C version converts the PS2 keys to ascii for MCU projects.
David M.
Posted: 08:48pm 30 Jan 2013
Yes that is an option, but I don't want more then about 8 buttons anyway(up,down,left,right,enter,and four or five other special buttons), so the CG chips will do the job wonderfully, and as I am already ordering a CMM from them...
It is something I can certainly look into later though if I needed more buttons...
MOBI
Posted: 09:18pm 30 Jan 2013
   grogster said  I don't want more then about 8 buttons
Were you planning on connecting the keypad up to the PS2 - I don't remember how it interfaced to the Maxi. Or were you planning on leaving the PS2 connected and go in via somewhere else?
David M.
Posted: 09:44pm 30 Jan 2013
No keypad at all.
A custom layout of buttons on a control panel.
Up arrow, down arrow, left arrow, right arrow, enter, and perhaps some other buttons.
The whole system is controlled via these buttons.
In the extended version of this idea, a standard keyboard is used on the KB socket, and the up, down, left, right and enter buttons are on I/O lines - this is probably how I will do it actually. Basic on-screen control via the arrows and enter, but when you need to enter in text etc, or edit a message, then the normal keyboard would be used.
It's all in the air at the moment - awaiting some form of CMM(be it Altronics or CG's) for me to start playing around with some code.
EDIT: Yes, yes - you can do the up,down,left,right all with the keyboard - true.
I am only experimenting at this stage, so everything is open for consideration!!!!
I will probably settle back on the standard keyboard for control keys AND text message editing etc, and not end up using the CG custom keyboard chip at all, but I wanted to tinker with it anyway, so... Edited by Grogster 2013-02-01
MOBI
Posted: 09:51pm 30 Jan 2013
  grogster said  A custom layout of buttons on a control panel
I was wondering if you've tried an I2C based key system, but if it is individual keys rather than a matrix, perhaps i/o pins is the way to go. With I2C though you only need the two I2C pins. Hope I'm not teaching Grandmother to ...
David M.
Posted: 10:15pm 30 Jan 2013
Hell no - you go at it!!!
"All knowledge is power."
I would not like to think that I had overlooked something obvious.
Posted: 10:58pm 08 Feb 2013
Things for CG to consider changing on the next release of the CMM:
- Stronger VGA socket. I think this has been discussed before by others.
- Perhaps also stronger keyboard socket?
- Fit the header on J7 at factory
- LABEL J7 as Bootloader or something like that, so we know where it is
- Fit header for PWM1 and PWM2 (the audio outputs)
- Have the option of a header for an external SD activity LED.
The last one would be very useful, cos then we could use a panel-mounted activity LED.
CircuitGizmos
Posted: 06:24am 09 Feb 2013
Grogster: Excellent suggestions.
Unfortunately a little late for CGCOLORMAX2 as it is too far along in the process.
Done. I would rather everything be SMT, but this one is through-hole now.
Looked into this. Kept the design as is. The socket/plug connection loosens up rather quickly.
I prefer to let the end-user decide if they want the headers in place. There is still an option to sell without/with headers.
Perhaps a CGCOLORMAX2WITHALLOFTHEHEADERSSOLDEREDINPLACE. Kinda a long part number, though...
Wish I had thought of that. It will be better documented, though.
See CGCOLORMAX2WITHALLOFTHEHEADERSSOLDEREDINPLACE above.
Hmm. Perhaps. The blue LED has been snugged up to the side of the SD socket so it is visible through the SD card slot in the black box.
Thanks for the feedback!
CircuitGizmos
Posted: 06:39am 09 Feb 2013
COLORMAX2 also has a better SD socket. It has card detect and push-in push-out (springy) removal.
The battery is bigger/flatter.
Input polarity on the external power no longer matters.
There is an alternate 1x4 header for the keyboard jack to facilitate using the CGKEYCHIP.
Posted: 03:32pm 09 Feb 2013
All sounds very positive.
Please don't think I was being critical in my post above - I was not...
Re-reading my post again today, it occurs to me that it might read that way, which was CERTAINLY not my intention.
CircuitGizmos
Posted: 03:39pm 09 Feb 2013
  Grogster said   All sounds very positive.
No worries, Grogster. I do appreciate the feedback.
paceman
Posted: 07:42pm 09 Feb 2013
The last one would be useful, cos then we could use a panel-mounted activity LED.
Hi CG,
I use my COLORMAX sitting at a normal height office desk with the box about 400mm away from my eyes - a pretty common situation I'd think. Neither of the SMD LED's is visible in that situation because the box blocks the line-of-sight. To see them you either need to have your head way too low to the desk or cut the SD card slot a lot higher above the card. I reckon panel mountable LED's would be better but I guess it's a bit late to mention this now for V2.
Greg
panky
Posted: 11:49pm 23 Feb 2013
Hi Circuit Gizmos,
Any news on when your CG Colormax2 will be shipping? Your website still only makes reference to the Colormax1. Will the price be the same?
Thanks Doug.
PS. My Colormax1 has been running live in the front boot of my caravan now for 6 weeks running my Caravan Battery Monitor program, and running flawlessly. Just waiting for Colormax 2 release to order another. D.
CircuitGizmos
Posted: 04:44pm 25 Feb 2013
Panky: A couple weeks at the earliest, to fit a production schedule. Final price yet to be determined (it shouldn't be too big of an adjustment.)
